Home > Technical (L322) > Whining noise on hard acceleration
n1cktdv8
I noticed a split secoind whine on the engine under a hard acceleration, with tin tent on the back, over the weekend. No performance issues, no warning lights, no real issue but it was at low speed if I accelerated you could hear the slight turbo whistle and a very dull whine over the top of it....solo I can't hear it, so is it a problem ready to go...when under load ?
This morning I had it plugged in and no faults reg'd.
Any ideas chaps Is this where I put the car details and a bit about myself ?........
Post #257866 6th May 2014 9:17am
n1cktdv8
Towed 'van today and once again in low gears and when pulling away the whining is back. Not a sound when solo, only when towing... Sad
No one any ideas ???
Read a few posts and they 'suggest' it could be a host of things but transmission, front diff, seals, belts ???
Getting worried now as garage can't find a fault and say a road test revealed nothing to worry about.... Is this where I put the car details and a bit about myself ?........
Post #258776 11th May 2014 5:08pm
I always get slightly more noise when towing, there is more load etc going through the drivetrain than standard, specifically the tc has extra work to do overcoming the inertia of the van.
So long as it doesnt get any worse i wouldnt worry to much, if anything was about to go bang i suspect that you would hear it solo as well.
Have you had all the oils done, transfer box, diffs and auto box? May be worth changing them if not done, there are magnets on the diff plugs and inspection of any residues would reveal any trouble. There is nothing that can't be fixed with a hammer😜😜
Post #258778 11th May 2014 5:16pm
n1cktdv8
I am dropping it with the lads in the indy tomorrow...they said they will do a fluids service, but like you - they say you will hear more noise under load when towing....it's pulling like a train and there is no lacking of horses !
Am hoping it's normal....lets see though...fingers crossed Is this where I put the car details and a bit about myself ?........
Post #258783 11th May 2014 5:47pm
Jmelvinbath
United Kingdom 2003 Range Rover Vogue Td6 Oslo Blue
Mine had this, it was the pulleys and pre-tentioners for the Air Consystem, something was seizing and a plastic bearing melted
Post #258931 12th May 2014 9:36am
RoryM
Ireland 2008 Range Rover Vogue TDV8 Santorini Black
I have a similar issue that still hasn't been sorted after numerous attempts. what was the fix for you? did you change a pre tensioner or pulley?
Post #258985 12th May 2014 1:46pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
have you tested the wife??..mine whines when I accelerate too hard Laughing GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #258996 12th May 2014 3:17pm
n1cktdv8
I have to be honest Paul...I haven't tested your wife so can't comment on the whine...though with a V8 surely it's a moan Rolling with laughter
Into Indy in the morning now, also to check a bloody rattle that's now appeared from the front left corner and disappears when I brake. I am hoping its a stone tuck in the sump guard area but that's wishful thinking on my part ! Is this where I put the car details and a bit about myself ?........
Post #259004 12th May 2014 3:45pm
paulmoran2
Rolling with laughter Rolling with laughter
you wouldnt last a minute mate....its usually a moan and a whine! GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #259005 12th May 2014 3:48pm
Jmelvinbath
Hi, I cut the pretensioner and belt off, then fitted a replacement... if it's melted when the bearing has gone like mine had;
a) it's a Censored to remove
b) you may need to look at the other pulleys the belt goes around, as mine had been damaged by the debris and the shredded belt.
Post #259030 12th May 2014 6:04pm
Bit trickier to get the belt on a tdv8, goes all over the shop, but i would reckon that the amount of load on the aux belt whild it varies under load slightly would not be affected by towing. Worth a check that all is running freely though, if its not it should be immediately apparent.
Doubt you would hear a stone also, my money on the arb drop links..... Whistle There is nothing that can't be fixed with a hammer😜😜
Post #259034 12th May 2014 6:09pm
n1cktdv8
oh well if you insist on it being your money on the drop links I'll have them done and an invoice sent through to you !!
All this is because I said how much I loved my Audi A8.... Rolling Eyes
Will mention drop links to Indy and see their response, will get all avenues checked and as we're doing a lot of towing in the coming weeks I am going to get the oils done... Is this where I put the car details and a bit about myself ?........
Post #259099 12th May 2014 10:50pm
Laughing
Drop links nice and cheap. Oem lemforder ones available from ecp and do-able on the ground with a spanner. Should be about £40. There is nothing that can't be fixed with a hammer😜😜
Post #259104 13th May 2014 6:08am
n1cktdv8
FYI....
Drop Links - no, they are fine
ARB's - are good too
the £5.66 stainless retaining clip for the pads is the culprit.... Whistle Is this where I put the car details and a bit about myself ?........
Post #260714 21st May 2014 3:16pm
Interesting! Nice cheap fix👍 There is nothing that can't be fixed with a hammer😜😜
Post #260759 21st May 2014 8:01pm
