Home > Technical (L322) > Whining noise on hard acceleration |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
Towed 'van today and once again in low gears and when pulling away the whining is back. Not a sound when solo, only when towing...
11th May 2014 5:08pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8513 |
I always get slightly more noise when towing, there is more load etc going through the drivetrain than standard, specifically the tc has extra work to do overcoming the inertia of the van.
11th May 2014 5:16pm |
11th May 2014 5:47pm |
Jmelvinbath Member Since: 12 May 2014 Location: Wimbledon Posts: 16 |
Mine had this, it was the pulleys and pre-tentioners for the Air Consystem, something was seizing and a plastic bearing melted |
12th May 2014 9:36am |
RoryM Member Since: 02 Mar 2013 Location: Ireland Posts: 51 |
I have a similar issue that still hasn't been sorted after numerous attempts. what was the fix for you? did you change a pre tensioner or pulley? |
12th May 2014 1:46pm |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
have you tested the wife??..mine whines when I accelerate too hard GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
12th May 2014 3:17pm |
I have to be honest Paul...I haven't tested your wife so can't comment on the whine...though with a V8 surely it's a moan
12th May 2014 3:45pm |
12th May 2014 3:48pm |
Hi, I cut the pretensioner and belt off, then fitted a replacement... if it's melted when the bearing has gone like mine had;
12th May 2014 6:04pm |
Bit trickier to get the belt on a tdv8, goes all over the shop, but i would reckon that the amount of load on the aux belt whild it varies under load slightly would not be affected by towing. Worth a check that all is running freely though, if its not it should be immediately apparent.
12th May 2014 6:09pm |
oh well if you insist on it being your money on the drop links I'll have them done and an invoice sent through to you !!
12th May 2014 10:50pm |
13th May 2014 6:08am |
FYI....
21st May 2014 3:16pm |
Interesting! Nice cheap fix👍 There is nothing that can't be fixed with a hammer😜😜
21st May 2014 8:01pm |
