Home > General > Mistake ? 2002 l322 v8 |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
+1 on that enjoy |
27th Mar 2014 6:59pm |
Paulmeds Member Since: 18 Mar 2014 Location: Devon Posts: 34 |
Hi, also does anyone know anywhere to get the dash pixels fixed in the Devon area.
1st Apr 2014 5:06pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Glad your getting there....
2nd Apr 2014 3:00pm |
Well when I said I was getting there didn't expect the next bill from the garage !!!!
11th Apr 2014 5:50pm |
Blimey, that sounds a bit pricey, hope you get a bit more luck from now on.... Pete
11th Apr 2014 6:02pm |
Well clean bill of health didn't last long. Next problem, I have an intermittent problem with front o/s indicator !!! Changed bulb but still only works when it wants, any ideas please.
13th Apr 2014 3:48pm |
Indicator is probably the bulb holder, take it out, switch it on and wiggle it about if it goes off you know it's the holder...
13th Apr 2014 4:01pm |
Hi, thanks will try the bulb holder. EAS says inactive HDI inactive ABS light comes on etc. seems not to like going into motorway mode. |
13th Apr 2014 4:16pm |
Can you raise and lower it with the switch?? Is the led light on in the center of the switch used to raise and lower it?? Pete
13th Apr 2014 4:35pm |
Hi, can't move it, the light in the middle does come on so it is locked. After 15mins in services all ok, 10 mins back on motorway same thing happens. |
13th Apr 2014 4:38pm |
First thing I'd try is to rebuild the pump, sounds like it's not producing enough pressure, get one of these and it's a thirty minute job.... and only £25
13th Apr 2014 4:43pm |
Thanks, my first thought was compressor & the kit is much cheaper than new one. I am not a great mechanic so is this kit an easy fit for an amateur ? |
13th Apr 2014 4:50pm |
It's pretty straight forward, see this video and you can judge if you feel up to it....
13th Apr 2014 4:55pm |
hi, will watch video see what I think. thank you very much for the offer of fitting, very kind of you but I reckon the petrol to get there would buy a new compressor !!! again thanks for the help and information, I will keep you updated. |
13th Apr 2014 5:06pm |
