Home > General > Mistake ? 2002 l322 v8
Page 3 of 3 <123
Paulmeds
England 2002 Range Rover HSE 4.4 V8 Baltic Blue
Hi, I have purchased the compressor repair kit, will give it a go with a mates help, looks straight forward. Going to test the bulb holder in the morning see if that is the fault, if it is do I have to buy a new unit or can I just get the holder ?
Thanks
Post #254417 14th Apr 2014 4:07pm
Good luck with the compressor, you may be able to gently bend the contacts on the bulb holder so it grips the bulb harder, not sure if it's available separately. Pete
Post #254477 14th Apr 2014 10:48pm
Dolphinboy
If you are getting hdc and abs warnings as well it may be corrosion on your abs module situated in the rear of the engine compartment in the middle, near the firewall. Sometimes the connectors get a bit of green corrosion on them and this can interfere with the link and as it is a looped system, it sets off other ecus at the same time. Worth having a look inside your abs module. Only a 2 minute job. Thumbs Up
Post #254480 14th Apr 2014 11:39pm
ebajema
Sorry to hear Paul. I understand what you are going through, my 4.2 SC had a lot of "backlog" work and I also had some unfortunate extra things go wrong :
- Front air bags worn (normally starts at that age of car), new struts 500 GBP (labour was free for me Smile )
- Suspension bushings all over, cost some 500 Euro (free labour still)
- Fuel pump (cheap find by Kingpleb/Will for 50 GBP iso of 400+ GBP)
- Clean fuel system (no cost really)
- Rear brake calipers
Extraordinary ones :
- AC packed up, new one 1000 Euro
- Both oil to water coolers (transmission and engine) blown, lot of work to clean up, plus new coolers. Say 2000 Euro altogether
- Gearbox solenoids replaced 300 Euro
Plus some small stuff, parking sensors for example.
I guess our cars will never be super reliable or cheap in any way shape of form and you can get lucky and have a trouble free one or you have to make it trouble free. I hope that yours gets sorted soon and you have many many trouble free miles in it Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #254481 15th Apr 2014 12:00am
Paulmeds
Hi, thanks everyone. I am hopeful I am getting it right, really does run well & nearly everything is working now !! I am going down the route of making it a good one rather than hoping for a good one. Once the indicator, EAS issues done next on the list is gearbox service & terra clean, make sure all is clean & renewed. Will be nice to finish it all & enjoy hopefully !!
Will check abs module first thanks very much, will let you know.
Post #254597 15th Apr 2014 5:39pm
Paulmeds
Thanks Haylands, bulb holder worked, £7 fix very rare on this car.
Compressor kit arrived, so that is next job.
Post #254893 17th Apr 2014 6:51pm
Good luck with it, watch the video a couple of more times, there's nothing tricky to do, will be fine... Very Happy Pete
Post #254936 18th Apr 2014 8:37am
Paulmeds
hi, have some free time this week so was going to do the compressor kit but thought I would just check through paperwork on the car and found a receipt for the following - compressor-suspension levelling £299.00 dated 15/2/2012.
so am guessing it had a new compressor fitted 2yrs ago and has only done about 10,000 miles in that time. So before I start stripping the compressor has anybody got any ideas please,
Post #255443 21st Apr 2014 5:02pm
Could try cleaning the ABS plug and seeing if that works.... Pete
Post #255444 21st Apr 2014 5:10pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
As above, sounds like an ABS problem if you are getting the ABS light on as well as the others. A lot of the systems are interlinked and use each others sensors (ABS,HDC,EAS) so an ABS fault could also disable the EAS (can't tell the speed in order to raise/lower for motorway mode) and HDC which uses the ABS to brake the wheels.
I can't think of a situation where an EAS system fault would put on the ABS light.
You need to check the fault codes, my money is on a wheel speed sensor or ABS wiring (as above).
If you are planning on keeping your rangey for a while and are happy doing a bit of DIY to save money then I suggest getting a code reader/reset tool and recommend the IID tool. Not cheap but will save the money you spend on it several times over against garage bills.
Post #255488 21st Apr 2014 9:21pm
bigdave1947
United Kingdom 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Paulmeds wrote:
Hi, also does anyone know anywhere to get the dash pixels fixed in the Devon area.
Thanks
Did you have any luck finding someone to repair the pixels in Devon. I have a replacement LCD but dont fancy the job so looking for someone to do it.
Post #409298 14th Oct 2016 1:26pm
Paulmeds hasn't posted since Oct 2014 on anything so I doubt you will get a reply... several places on eBay that do it and have a quick turnaround...
Don't send your new bit with it though, if it fails they will say it's your part, usually it's how the repair was done that fails but they will have an outer if you supply the parts... Thumbs Up Pete
Post #409445 15th Oct 2016 10:39pm
bigdave1947
Many thanks for that I seen a place that for £180 will take the car apart and repair whilst you wait. I dont have a problem with the duff display but on the last MOT the tester put unknown mileage down on the form which cocks up my insurance warranty! I read somewhere that the odometer is stored on the ECU but I have tried to look using Torque Pro with OBD2 and cant find it?
regards Dave
Post #409460 16th Oct 2016 7:28am
Page 3 of 3 <123
