![]() | Home > My Range Rover > Project Fatty off roader....PICTURES NOW BACK |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8444 ![]() ![]() ![]() |
Thanks for the comments chaps...
Thing is the V8 kicks out a good bit of heat and as long as the vapouriser is properly tapped into the heater matrix circuit there's no need to worry, as long as there is good flow over it it won't freeze |
Yep, no problem when it's hot, it's starting it on LPG from cold that does damage...
£150 isn't expensive, they are a true bargain when you work out the cost of making good ones up the same thickness |
Been playing again.... getting the inside to where I want it
Each to their own Andy, be a boring world if we all liked the same thing...
B9er Member Since: 10 Dec 2012 Location: Larne Posts: 191 ![]() ![]() ![]() |
Not sure if the carbon look is to my ultimate taste, but still way better than what's hidden beneath |
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 ![]() ![]() ![]() |
I fancy doing my trim but I think I'll have to have a wee practice first!!!
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Nice workmanship it seems, but not the right colour on a Rangie, so ^^^+1 ![]() Current RANGE ROVER Vogue 4.4L SDV8 - 2013 - Indus Silver, on Almond. RANGE ROVER Vogue 4.4L V8 - 2002 - ex-2003 G4 Challenge Event Vehicle, Stage 3: Australia RANGE ROVER HSE 4.4L V8 - 2004 - one-of-one Overfinch RANGE ROVER P38a 4.0L V8 - 1999 - ex-2000 TReK Event Vehicle: South Africa Previous: RANGE ROVER Vogue 4.4L TDV8 - 2012 - RANGE ROVER 3.6L TDV8 x3 - RANGE ROVER Td6 x1 - RANGE ROVER Classic 3.5L V8 x1 |
Seems it's very "marmite" then.... love it or hate it.... although looks like I'm in the minority.....
Did a mates car in this about two years ago and it's still fine, has to be applied properly, use primer for edges etc and it should last for years, you can always take it off again as it doesn't damage the underlying wood, even the primer comes off easily as it's water based... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Good to know mate. Can you recommend a specific make? |
Paul,
Cheers Pete. |
Started changing the interior lights for LED's as I prefer the white light
