Home > My Range Rover > Project Fatty off roader....PICTURES NOW BACK
Page 3 of 31 <123 4 ... 293031>
Thanks for the comments chaps...
Kingpleb, thanks, I saw those bit's but there a bit expensive, I can make my own stuff and will go down that route thanks...
I updated the software on the LPG so it will now start on LPG when hot, it is set to switch over from cold at 35degC, you can force them to start on LPG when cold but this isn't a good idea with the modern injection LPG systems, the gas can freeze in the vaporiser and damage the diaphragm or in the pipes and cause misfires, it also damages the injectors... 35deg is about the lowest temp you want to go, mine takes less than a mile to get to temp..
With the old single point systems it was fine to start on LPG from cold, in fact the first systems used, which was in Australia, used LPG all the time with no petrol use at all, they found that after many tens of thousands of miles on LPG, someone would run out of gas, switch to petrol only to find it had been dormant for so long it wouldn't work.... so they made them start on petrol every time just to keep the system working OK.
More myths and legends of LPG......!!!
Your right about using the petrol up, it starts to lose octain rating after about 3 months Pete
Post #249479 20th Mar 2014 8:38pm
Thing is the V8 kicks out a good bit of heat and as long as the vapouriser is properly tapped into the heater matrix circuit there's no need to worry, as long as there is good flow over it it won't freeze Wink
I did some calcs on the underbody metalwork but for the thickness of the mantec stuff your talking £££ massive bucks basically and then fitting it to the right mounting points would need time. £100 for the sump guard and £15 for a fitting kit and 30mins under the car was a bargain to me and it does and HAS supported the full weight of the front end of the car so I reckon was at least 1100kg and hasn't bent or done anything but get a small scrape mark on it. The standard plastic guff would barely even take 5% of that Very Happy FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #249482 20th Mar 2014 8:53pm
Yep, no problem when it's hot, it's starting it on LPG from cold that does damage...
I prefer to make my own bit's for offroading, I'm sure that Mantec one is fine though... Pete
Post #249623 21st Mar 2014 2:12pm
£150 isn't expensive, they are a true bargain when you work out the cost of making good ones up the same thickness Wink
I had been tempted to buy a few more like the one I got and cut them up to make an under body skid but will be returning my FF to road going only after one more green-lane shout and event before she gets sold on once working and in perfect condition again Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #249793 22nd Mar 2014 11:49am
Been playing again.... getting the inside to where I want it
Got rid of that dog poo looking wood on the dash, can't understand why Land Rover would make wood look so much like cheap plastic, most of the other types of wood looks nice but you can't see the grain in this type, just looks like brown plastic, never been a lover of wood anyway.... Just the door cards to go to get rid of it all....
 Pete
Post #250077 23rd Mar 2014 6:55pm
andy180
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Wood or piano black looks much better IMO carbon fibres not my cup of tea.... it belongs in supercars and Vauxhall Corsa's belonging to 17 year old's. Now: BMW 640d M Sport, Alpine White
Gone: Range Rover 4.4 V8 Vogue, Zambezi Silver, Charcoal Oxford Leather
Also: Mk1 Audi TT 1.8T Quattro, Brilliant Black
[URL=]
[/URL]
Post #250083 23rd Mar 2014 7:17pm
Each to their own Andy, be a boring world if we all liked the same thing...
I like the textured look of fake carbon fiber.... sad I know.... Laughing Laughing Pete
Post #250085 23rd Mar 2014 7:20pm
B9er
Northern Ireland 2010 Range Rover Autobiography 5.0 SC V8 Java Black
Not sure if the carbon look is to my ultimate taste, but still way better than what's hidden beneath Very Happy
As you say, each to their own, and if it pleases you then job very well done, enjoy Thumbs Up Should've been old enough to know better...doh!
Current 2010 5.0 SC Autobiography
Previous 2006 TD6 Vogue SE
Previous 1998 P38 4.6 Vogue Autobiography 50 (No 10)
Post #250144 23rd Mar 2014 9:55pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
I fancy doing my trim but I think I'll have to have a wee practice first!!!
Also are the wraps not bad for peeling?
Post #250156 23rd Mar 2014 10:52pm
verydisco
Nice workmanship it seems, but not the right colour on a Rangie, so ^^^+1 Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #250180 24th Mar 2014 9:08am
Seems it's very "marmite" then.... love it or hate it.... although looks like I'm in the minority..... Laughing
Did a mates car in this about two years ago and it's still fine, has to be applied properly, use primer for edges etc and it should last for years, you can always take it off again as it doesn't damage the underlying wood, even the primer comes off easily as it's water based... Pete
Post #250297 24th Mar 2014 7:20pm
paul271
Good to know mate. Can you recommend a specific make?
Post #250340 24th Mar 2014 9:29pm
Paul,
This stuff is 3M Di-Noc carbon wrap, there are lots of cheap fakes from China, they even say 3M on the back, just get it from a reputable seller, I got it from underground-graphics on ebay but he only seems to do carbon in various colours.... Pete
Post #250533 25th Mar 2014 6:34pm
paul271
Cheers Pete. Thumbs Up
Post #250549 25th Mar 2014 7:32pm
Started changing the interior lights for LED's as I prefer the white light
Before
After
Changed the rear upper hub rosejoints...
Think this one had seen better days....
And did the front ARB drop links, put another post on about it but still having trouble finding the clonk from the front
See here
http://www.fullfatrr.com/forum/topic24654.html
Also I've done some more general tidying up of the LPG system install, and changed the Thermistor in the vaporisor as it was starting to fail and was giving an erratic reading..
I do like something to play with..... lucky really..... Whistle Pete
Post #252458 3rd Apr 2014 4:28pm
