Home > In Car Electronics (L322) > Reverse Camera Wiring Issues
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
I tried to wire in my reverse camera over the weekend, I've got a bmwnav lead with aux inputs etc that plus into the white wiring loom off the TV tuner
The instructions state that u have to fit a earth wire into pin 17 on the blue plug loom which I've done, when I earth the wire it cuts out the screen etc
The question is that that camera feed is rolling when connected, I've looked online and it suggests that it is a PAL & NTSC issue however my concern is the minute the earth is wired in it blanks the screen out so once wired in when I get a NTSC camera does that work off a earth fees so the camera will ways pull the live and switch on the earth??
Also can anyone advise if there is a better wiring harness I can fit that would use a PAL camera??
Sorry for all the questions but I found it strange that the earth is the switching point on this loom
Thanks
Neil
Post #248920 18th Mar 2014 9:04am
Winchester101
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Cliffs my instructions from park my auto pin 17 White goes to a relay 1994 softail full stars n stripes custom harley davidson
Post #249212 19th Mar 2014 5:09pm
Once you get the NTSC camera connected up you should see an image when you short pin 17 to earth.
As Winchester101 suggests, you need to then sort out the wiring from the gear lever so that when you go into reverse it opens the relay to short pin 17 to earth and show the reverse camera image.
There are lots of images re pin assignments etc in my ICE thread on creating a carpc
http://www.fullfatrr.com/forum/topic8786.html .
Post #249219 19th Mar 2014 5:59pm
A rolling camera feed indicates you have either a PAL camera or a PAL/NTSC camera.
I had the same symptom.
The problem is most sellers of reverse cameras don't know what they are selling they could be any format irrespective what they advertise.
For your car you definitely need a dedicated NTSC camera which surprisingly are not too readily available in the UK.
Took me 3 goes to get a dedicated NTSC camera. Big Cry
Post #249220 19th Mar 2014 6:02pm
Winchester101
Easy when ya know how Bow down Bow down 1994 softail full stars n stripes custom harley davidson
Post #249225 19th Mar 2014 6:22pm
jeffridj
United Kingdom 2003 Range Rover Vogue 4.4 V8 Alveston Red
Or of course you can use the PAL camera by changing the car to PAL using Navcoder and interface. 2003 4.4 V8 Vogue
Added Tow Bar, Reversing Camera, Freeview box
Post #249867 22nd Mar 2014 5:25pm
cliffy
Hope this is on the IIDTool
Post #249883 22nd Mar 2014 6:34pm
jeffridj
No idea sorry, I don't have one. 2003 4.4 V8 Vogue
Post #249902 22nd Mar 2014 8:38pm
kaskass
United Kingdom 2002 Range Rover Vogue SE 4.4 V8 Java Black
When I purchased my RR the wiring was a mess, camera didn't work (although it was wired) spoke to Russel from Park My Autos he has fitters nationwide and pointed me in the direction of one. One day later and £40 my camera works!
Hope this helps Smile
Post #250369 25th Mar 2014 1:48am
