![]() | Home > Technical (L322) > Gear change harsher? |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
I had something similar a few months ago but mine was when I kicked down it would think about it then thud into gear took it to the main stealer and they said it was a software upgrade which they did and it is better but not quite how it should be so taking it back in a couple of weeks as still under extended warranty |
Time for a gearbox service/oil change maybe? |
leem5 Member Since: 14 Mar 2013 Location: North Posts: 46 ![]() ![]() |
Think it may well be time for a service. |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
There are various software changes the Dealer can make to the gearbox ECU, as the car comes out of the factory with a default programme to suit most countries and terrains.
Ok, with a service seeming to be the best option, can anyone recommend a place near Newcastle/ Durham area?
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
+1 for the gearbox service.
We'll had an automatic gearbox specialist look at it yesterday, no codes but went for a test drive and came back with the conclusion the at the torque converter is on its way out? So do I now get the box opened up £1800+ vat or change the oil and se where that leads to? Any advice would be appreciated.
If it were me I'd have the oil service done first.
nazz Member Since: 26 Jan 2013 Location: putra heights Posts: 15 ![]() ![]() ![]() |
ok guys,
