Home > Technical (L322) > IIDtool :)
Page 3 of 8 <12345678>
verydisco
blueRR2006 wrote:
In my case, I like the BT option on tablet/smartphone, you can stand outside your RR to make EAS adjustments/modifications
You geek! (I plead guilty too...) l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #243262 17th Feb 2014 11:13pm
Andy
I've just changed the access height from the standard -40mm to -70. It's like getting into a normal car now!
Post #243266 18th Feb 2014 12:06am
RR2008HSE
goncalo wrote:
I'm thinking to purchase the IIDtool and the manly reason is to control the EAS heights.
I see many L322 with more height than mine i like the look much more.
But i have some questions related.
1 - How can i know the normal heights for my car?
2 - If i increase the height do i compromise anyway the safety when i'm driving?
3 - Can i step up 2 different heights one for normal driving and other to the automatic high speed height?
Thanks
1 - I think the IID gives the current value when changing. (Not 100% sure.) The IID does back up all values when you first plug it in.
2 - Obviously, a higher car has a higher centre of gravity. Sometimes that's a factor. I haven't played with the heights as I think JLR probably spent a lot of time and £££ getting them to what they are. Of course, some posters here have had very good reasons to change them e.g. Doing a limbo into a parking garage.
3 - Sorry, no idea.
Post #243269 18th Feb 2014 1:15am
goncalo
Portugal 2007 Range Rover Vogue TDV8 Java Black
^Thanks for the reply.
1 - I Ask how can i know my car normal heights because i use to see everyday near me an FF just equal as mine, same year, same color, same kind of 19'' wheels and same size of tires ( factory settings) and the distance from the tire to the car is more than mine, the car is taller and like much more the looking than mine!
I want to know the normal heights because i don´t if my FF is lower than normal or if the other FF is higher than normal.
 Ex-FULLFATTY now downgraded
L494 RRS P400e Dynamic Narvy Black
-------------------------------------- gone
6 | FF-RR 2007 TDV8 Vogue JAVA BLACK
5 | FF-RR 2003 TD6 Vogue Bonatti grey
4 | Ex-RR 2000 P38 automatic
3 | Ex-RR 1994 300tdi classic
2 | Ex-RR 1993 200tdi
1 | Ex-RR 1991 turboD VM engine
Post #243317 18th Feb 2014 10:30am
credit to joe90.
Post #243340 18th Feb 2014 11:38am
goncalo
Many Thanks STAN!!! Very Happy
i didn't know where to look! Ex-FULLFATTY now downgraded
Post #243344 18th Feb 2014 11:47am
Post #243349 18th Feb 2014 12:00pm
a016738
United States 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Here's a question...my tool only allowed me to adjust my suspension up 10mm because one of the wheels was only that far away from the max absolute value allowed by the tool. Would removing this 10mm lift and recalibrating everything according to the instructions provided by GAP reset the height values to allow for a greater lift? Seems I should haves been able to get more than 10mm out of the adjustment...especially since it was really only the one wheel with a height value that high.
Is this the very reason why the calibration function exists?
Or could one of my rods be out of whack...necessitating that wheel to be lifted to a higher height value?
Thoughts?
-John
'07 RRSC
Post #243372 18th Feb 2014 2:30pm
pretty sure the IIDTool only allows changes of 10mm in one session, try again and see if you can go down another 10mm..
Post #243373 18th Feb 2014 2:37pm
a016738
It was actually 13 that it would have allowed me but I kept it at 10 so I could remember how much I'd adjusted it so I could go back to the original setting. Wanted to keep it in increments of 10 so I'd remember it...so 10 was my self imposed 10mm interval max.
But just to rule that out I just tried it again and it would still only give me another 3mm. The other day I checked live values for the heights and sure enough they were very close to the absolute max for the tool (250?).
-John
'07 RRSC
Post #243375 18th Feb 2014 2:44pm
dingg1
dropped my settings 20mm all round in one go
Post #243383 18th Feb 2014 4:00pm
maybe i was thinking of the rsw tool.. Rolling Eyes
dingg1, whats the drive like on 20mm lower ? any pics..
Post #243384 18th Feb 2014 4:02pm
dingg1
drives fine - can throw it around corners a wee bit quicker
offshore at the minute and really do need to take pics , as its looking a lot better than my last photos Smile
Post #243385 18th Feb 2014 4:11pm
thanks, looking forward to seeing yours... Thumbs Up
Post #243386 18th Feb 2014 4:16pm
goncalo
Stan i have the standard heights! ...and 18'' Wheels.
If i increase 20mm do you think it can be unsafe for driving?
I'm the only one who looks the taller look? Ex-FULLFATTY now downgraded
Post #243401 18th Feb 2014 5:26pm
