Home > Technical (L322) > TDV8 Alternatorh how to change/replacement pics |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Respect how long did it take so far? Present :2008 TDV8 HSE
23rd Jan 2014 8:17pm |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 |
T24RES, I would be very interested to know what the voltages are with the new alternator, especially the under load readings you get. I noticed you were getting 11.7 volts with everything turned on with the old alternator, does the new one improve this at all? |
23rd Jan 2014 9:45pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
About 2hrs to get the alternator out. Hopefully less going back in as now I know my way around. Just in from work, fingers crossed for a couple of dry hours to finish off.
24th Jan 2014 2:12am |
Remove the under trays x2, most people will be able to get underneath on extended mode. I left the drivers door open for a few minutes whilst disconnecting the battery so the suspension didn’t come down.
27th Jan 2014 6:23pm |
Excellent work well done Present :2008 TDV8 HSE
27th Jan 2014 7:56pm |
Nice job T24RES and great pics and description of work.
27th Jan 2014 8:27pm |
Sounds like reasonable figures to me. I'll test in a similar fashion as soon as the rain slows up for comparison. |
27th Jan 2014 8:46pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
Great write up, i shall pass have a go now i have some pics to go by😄
28th Jan 2014 7:51pm |
Bleeding the system was ok, slowly does it. Took out the black plug on the header tank, this helps to bleed the system. Then allowed to cool and topped up later |
28th Jan 2014 7:57pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
nice write up, wiki'fied... |
28th Jan 2014 8:02pm |
T24RES did you ever get a chance to check the voltages since fitting the new alternator. I am still curious to see how the new alternator behaves under extreme load compared to the old one. |
5th Feb 2014 8:50am |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Any tips on how to get the alternator past the black pipe in front of it, got mine loose and I just can't find a way of getting it pat the pipe.
8th Feb 2014 5:21pm |
Pm sent Ian |
8th Feb 2014 7:12pm |
These are the voltages read from the IID display: Tickover = 14.1 - 14.2v Full Load @ tickover = 12.2-12.3v ((rear seats/front seats/front & Rear screen/full fan/headlights/radio) Full load @ 2000rpm = 14.1 14.2v Ian |
11th Feb 2014 11:31am |
