Home > Technical (L322) > TDV8 Alternatorh how to change/replacement pics |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
worth doing just had mine done. Mike and Mechanics member did his theres a post about it if you do a search he didnt need to remove as much as first thought think it took him 6 hours leisurely between cigars and tea Present :2008 TDV8 HSE
18th Jan 2014 4:12pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
I'll check that out, thank-you.
18th Jan 2014 5:10pm |
If alternator showing at 14.8 that's fine. Mine would only show an average of 13.5 whilst driving. I suspect it might be the battery. Battery charged when engine off should read 12.8 volts and after a while 12.7 or so. I had my Bosch replaced under warranty so I knew it wasn't battery. Certainly seems a bit more investigation is needed but 14.8 is bang on perfect for alternator. Another thought is it might be voltage regulator ? Before mine failed I also had a whining noise that increased and decreased with speed .Good luck with your investigations Present :2008 TDV8 HSE
18th Jan 2014 5:32pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7944 |
Worth double checking the connections on both the battery and alternator. |
18th Jan 2014 6:06pm |
kungfupanda Member Since: 24 Jun 2013 Location: Manchester Posts: 221 |
Is the voltage regulator a part of the alternator unit itself? Googsy, I started to notice this whining before Xmas and initially thought it was the gearbox. |
18th Jan 2014 6:17pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Test the voltages by putting the probes on the battery terminals both with the engine off and with it running about 2000rpm. |
18th Jan 2014 6:20pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8617 |
Getting slowly more and more nervous...
18th Jan 2014 7:20pm |
There are 2 lr part codes depending in vin number....
18th Jan 2014 7:40pm |
My VIN is after too, what does that mean? |
18th Jan 2014 8:18pm |
I'm not sure car was registered march 2008 build was Dec 2007 so maybe before vin can't check as it's dark. If it's after vin then what that means is it has the improved version alternator less prone to failing. Present :2008 TDV8 HSE
18th Jan 2014 8:48pm |
That's the theory I'm thinking about. Mine is also dec 07 reg but that is not really indicator of build date, and is just after the swap in terms of vin.
19th Jan 2014 8:52am |
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 |
14.8 is spot on, but maybe worth putting everything on electrical in the car & rechecking. It maybe that its breaking down under load. If you do change it & need any advice feel free to ask. It is a pig but not that complicated. Good luck Mike Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
19th Jan 2014 11:47am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
A, change the battery (as its under warranty) for piece of mind... B, when your testing your alt output, 14.8v after 2mins... Leave the car running and then put on all the lights, the heated screens, the blowers etc etc etc which will really make your alt work hard and keep an eye on that reading... It will fluctuate slightly but should not drop much below 13.5v... Much under that and you have issues sir |
19th Jan 2014 12:10pm |
Thanks Craig,
19th Jan 2014 4:40pm |
