![]() | Home > Technical (L322) > TDV8 Alternatorh how to change/replacement pics |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
I'll check that out, thank-you.
If alternator showing at 14.8 that's fine. Mine would only show an average of 13.5 whilst driving. I suspect it might be the battery. Battery charged when engine off should read 12.8 volts and after a while 12.7 or so. I had my Bosch replaced under warranty so I knew it wasn't battery. Certainly seems a bit more investigation is needed but 14.8 is bang on perfect for alternator. Another thought is it might be voltage regulator ? Before mine failed I also had a whining noise that increased and decreased with speed .Good luck with your investigations |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7975 ![]() ![]() ![]() |
Worth double checking the connections on both the battery and alternator. |
kungfupanda Member Since: 24 Jun 2013 Location: Manchester Posts: 224 ![]() ![]() ![]() |
Is the voltage regulator a part of the alternator unit itself? Googsy, I started to notice this whining before Xmas and initially thought it was the gearbox. |
Test the voltages by putting the probes on the battery terminals both with the engine off and with it running about 2000rpm. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8687 ![]() ![]() ![]() |
Getting slowly more and more nervous... |
There are 2 lr part codes depending in vin number....
My VIN is after too, what does that mean? |
I'm not sure car was registered march 2008 build was Dec 2007 so maybe before vin can't check as it's dark. If it's after vin then what that means is it has the improved version alternator less prone to failing. Present :2008 TDV8 HSE
That's the theory I'm thinking about. Mine is also dec 07 reg but that is not really indicator of build date, and is just after the swap in terms of vin.
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 ![]() ![]() ![]() |
14.8 is spot on, but maybe worth putting everything on electrical in the car & rechecking. It maybe that its breaking down under load. If you do change it & need any advice feel free to ask. It is a pig but not that complicated. Good luck Mike |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
A, change the battery (as its under warranty) for piece of mind... B, when your testing your alt output, 14.8v after 2mins... Leave the car running and then put on all the lights, the heated screens, the blowers etc etc etc which will really make your alt work hard and keep an eye on that reading... It will fluctuate slightly but should not drop much below 13.5v... Much under that and you have issues sir ![]() ![]() |
Thanks Craig,
