Home > Technical (L322) > 'Hack' for TV/DVD on the Move: UPDATED |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 410 |
A small video of a world cup game.....
9th Jul 2010 5:47pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35274 |
ok i'm a bit confused , does pressing 753/ok actually switch on the 'tv in motion' or do i have to do something else like go through the diagnostics to a particular page .. |
27th Jul 2010 3:22pm |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
After selecting the 753 and OK, you then select the 'video input test' from memory and then select TV and then the PAL button and you should have TV then visible. One thing I did note was that you need to be on the channel you want to watch before doing the procedure as when you then use the left/right arrows (below touchscreen or on steering wheel) this searches for the next channel (as oppossed to skips to the next one in your 'listings') which on mine defaults from the freeview one I am on and goes to the analogue ones of which there are none in my area.
27th Jul 2010 10:27pm |
thanks mate, so the additional procedure of selecting video input test ,then selecting tv ,and then pal , completes the 'unlock'.. |
28th Jul 2010 7:15am |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 |
correct |
28th Jul 2010 9:33am |
ta muchly.. |
28th Jul 2010 9:50am |
I know I'm stating the obvious here, but this will reset back to normal once you turn the ignition off so you would have to repeat the procedure next time you start up. Steve
28th Jul 2010 4:57pm |
yarp, i found this out and i suppose the only permanent solution is by cable and navcoder... |
28th Jul 2010 5:09pm |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 863 |
Sooooooooooooooo, you were watching TV, whilst driving and videoing yourself doing it! You just needed to be applying lipstick and drinking a coffee to complete the set! My Previous RR's! 2018 P400e Autobiography 2008 TDV8 Vogue 2006 TD6 Vogue 2007 TDV8 Vogue 2007 RRS (I know, it doesn't count!) 2005 4.4 Vogue on LPG 2005 TD6 Vogue 2003 4.4 Vogue 2001 4.6 HSE 2000 2.5 DHSE 1999 4.6 HSE 1997 4.6 HSE on LPG 1995 2.5 DSE 1989 3.9 EFI classic 1988 3.5 EFI classic |
28th Jul 2010 5:11pm |
This is where you need someone who can actually reprogramme the software to default to TV on without the need for a cable. Steve
28th Jul 2010 5:28pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6366 |
I decided it wasn't worth it for the number of times I would actually use it. Discovery 4 HSE
28th Jul 2010 6:21pm |
doublejay Member Since: 08 Nov 2009 Posts: 131 |
my biggest gripe has to be my co pilot (SWiMBO) can't change the sat nav whilst we're on the move. No reason why she shouldn't be able to declare herself passenger - maybe linked to weight on the seat, like a seat belt monitor - and change the nav. |
3rd Aug 2010 10:35pm |
budha Member Since: 03 Feb 2011 Location: london Posts: 27 |
you can get a module fitted(£250.00ish) which lets you have tv on at all times and has a secret button for switching it off again just in case. The new satnav maps and software upgrade to be able to change satnav destinations etc on the move. i have the 09/10 maps and it works a treat. |
11th Feb 2011 6:48pm |
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 |
Budha,
12th Feb 2011 9:37am |
