Home > Technical (L322) > 'Hack' for TV/DVD on the Move: UPDATED
Page 2 of 3 <123>
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
A small video of a world cup game..... Very Happy
Post #21984 9th Jul 2010 6:47pm
ok i'm a bit confused , does pressing 753/ok actually switch on the 'tv in motion' or do i have to do something else like go through the diagnostics to a particular page ..
Post #23348 27th Jul 2010 4:22pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
After selecting the 753 and OK, you then select the 'video input test' from memory and then select TV and then the PAL button and you should have TV then visible. One thing I did note was that you need to be on the channel you want to watch before doing the procedure as when you then use the left/right arrows (below touchscreen or on steering wheel) this searches for the next channel (as oppossed to skips to the next one in your 'listings') which on mine defaults from the freeview one I am on and goes to the analogue ones of which there are none in my area.
By the way, you can actually get a real time readout of your current speed (in Km/h) on one of the diagnostic menus. I assume it gets the info from the same source as the analogue display as it mirrors it exactly (i.e. doesn't use the GPS system etc).
I wonder how many other codes are available for this particular hidden menu but obviously I'm not going to start to input random 3 digit numbers to see if anything happens! Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #23417 27th Jul 2010 11:27pm
thanks mate, so the additional procedure of selecting video input test ,then selecting tv ,and then pal , completes the 'unlock'..
Post #23446 28th Jul 2010 8:15am
sleepezy
correct Thumbs Up
Post #23462 28th Jul 2010 10:33am
sleepezy wrote:
correct Thumbs Up
ta muchly..
Post #23464 28th Jul 2010 10:50am
RRVSE
I know I'm stating the obvious here, but this will reset back to normal once you turn the ignition off so you would have to repeat the procedure next time you start up. Steve
Post #23561 28th Jul 2010 5:57pm
yarp, i found this out and i suppose the only permanent solution is by cable and navcoder...
Post #23566 28th Jul 2010 6:09pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Sooooooooooooooo, you were watching TV, whilst driving and videoing yourself doing it! You just needed to be applying lipstick and drinking a coffee to complete the set!
Laughing My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #23568 28th Jul 2010 6:11pm
RRVSE
This is where you need someone who can actually reprogramme the software to default to TV on without the need for a cable. Steve
Post #23580 28th Jul 2010 6:28pm
I decided it wasn't worth it for the number of times I would actually use it. Discovery 4 HSE
Post #23589 28th Jul 2010 7:21pm
VMPP
Laughing
nopes
Was at the same time texting someone.... Very Happy Very Happy Very Happy
Post #23623 29th Jul 2010 12:43am
doublejay
my biggest gripe has to be my co pilot (SWiMBO) can't change the sat nav whilst we're on the move. No reason why she shouldn't be able to declare herself passenger - maybe linked to weight on the seat, like a seat belt monitor - and change the nav.
Post #24202 3rd Aug 2010 11:35pm
budha
England 2006 Range Rover Autobiography 4.4 V8 Java Black
you can get a module fitted(�250.00ish) which lets you have tv on at all times and has a secret button for switching it off again just in case. The new satnav maps and software upgrade to be able to change satnav destinations etc on the move. i have the 09/10 maps and it works a treat. Surprised
Post #49771 11th Feb 2011 7:48pm
AMD
Budha,
Would you like to tell us where we can buy this piece of kit, or is that a secret too? Wink and why would want a secret button??. Current MY2020
Gone: 1 x L405 and 2 x L322's
Post #49823 12th Feb 2011 10:37am
Page 2 of 3 <123>
