![]() | Home > Maintenance & Mods (L322) > LED Indicator Upgrade For Early Cars |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
Many thanks gents.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
Pre-07 facelift, the cars had orange indicator lenses - then fashion changed and they went clear
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
i have the facelift lights, and upgraded the sidelamps to non error 501 types, and they look great, i then changed the amber 'egg' bulbs for those clear ones that flash orange. they also look good, as they are filament type, and cant be 'seen' as they look clear. i tried a few high watt led bumper fog lights, but they were really poor light, as were the high beam LED's so i stuck with the normal ones. at the rear i have the SC lights, and also used those funny clear lights, that flash the correct colour, but look a bit green, and cost a lot. i was gonna change my number plate lights, but they light up the plate even more than normal, making me easier to see making an escape from whoever, so i left them alone too.! |
Thanks pld118, will continue a search of the net.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Ideally the cree LED's need to emulate the filament bulb to get the reflector in the indicator to work correctly... If you were to use just forward facing LED's then surely the dispersal of the light would be incorrect... |
These are pictures of the bayonet fit, plug and play, error free, main indicator LED bulbs that I've happily got on the front and rear of the SC now (they've been on over a month).
Look right to me |
Excellent. Looks like I'm best making sure the bulbs I get have sideways facing LED's, as you chaps have already suggested.
Well these seem to be the cheapest 30w on the bay of e.........
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
pretty sure 501's will fit in the reverse lights.. |
850 Lumen is quite bright I think as ours are 30W and are definitely 400 Lumen (850 Lumen applicable to the 30W bulb you're interested in Mark, according to the seller's claims anyway).
white crees give out more lumens than amber ones Ryan |
The reverse lamp bulbs are a small bayonette fitting stan (like an old type torch bulb) and the 501 is a push fit (front side light bulb) |
cheers Craig..
