![]() | Home > Maintenance & Mods (L322) > LED Indicator Upgrade For Early Cars |
Are they much brighter Stan? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35533 ![]() ![]() |
yes they are and the quick sharp on/off helps as well... |
Do you have a link for them please pal... |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7879 ![]() ![]() ![]() |
Ah - good shout on the lumens - nearly ordered them. Poss a bit bright then. Don't want drivers behind coming after me with a blunt instrument !
Thank you Stan |
I believe I have found a bulb suitable. A 20w Cree unit using 4 x 5w Crees.
Mark,
Mark, the top ones look like the wrong pin fitment and the reverse look a bit to long , best measure the length available to be sure.. |
Cheers Gents.
Ahh, loving the idea of the reverse lights |
@ mjd & C-T-C
couldn't find any ref to what type of bulbs [pin wise] yours was Mark and i assumed they were like mine [offset]...good luck mate.. |
Thank you sir ![]() ![]() |
