![]() | Home > Technical (L322) > Black smoke and ENGINE SYSTEM FAILURE messages |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35511 ![]() ![]() |
i'm not familiar with the tdv8 engine but the DPF springs to mind, try a forum search and see if the symptoms are the same.. ... - .- -.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Plug into diagnostics for the codes my friend...Kind of p |
Too early for a DPF Stan... 2010> ish for DPF ![]() |
![]() Y. O. L. O. . |
Ahh, it's early love |
drivesafe Member Since: 19 Mar 2008 Location: Gold Coast Posts: 126 ![]() ![]() ![]() |
Thanks folks, kind of figured that would be the case, but just asked in case it was something as simple as the silencer solution on the air suspension. I suppose I should be grateful, this pussbox actually operated properly for just on a week. First time in 6 years. 2007 TDV8 Lux |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 754 ![]() ![]() |
It's worth checking the air hoses from the intercooler for splits - there's also 2 x 2 inch diameter hoses that are hidden under the engine cover, 1 on the rocker cover of each bank of cylinders. They would cause the same symptoms if they are split. |
BTW, again would an OBD tool help.
Thanks cass, I will check them in the morning. 2007 TDV8 Lux |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 ![]() ![]() |
Could well be the two intercooler pipes - just like the D3 one they split or delaminate and cause this. |
Thanks Martin, this is almost exactly what is happening to mine. In my case, it is fine on flat running but even the slightest hill and after a few seconds, lose of power and the message. If i accelerate up the same hill, it does not fail? Again, I will check all the pipes in the morning. Thanks again all. 2007 TDV8 Lux |
