Home > Technical (L322) > Groan.... its starting to do my head in .(
Needle
2003 Range Rover SE Td6 Java Black
Ok had a quick look on here but id be here for ever trying to find the solution Sad( , got a 2003 td6 full fat , problem was it felt like the HDC was kicking in and applying the brakes ( aggressively) but only when pulling away , would do it for a few days then disappear for weeks then come back , nothing coming up on the ID tool ,,changed all the wheel sensors , checked the connections on the abs modulator but nothing there,HDC /air sus / Abs lights coming up,,,HELP .(
Post #226575 2nd Dec 2013 7:35pm
Do the lights go out when you turn the steering wheel full lock to full lock but then come back on again later? Previously..
Post #226582 2nd Dec 2013 7:54pm
Needle
nope they stay on
Post #226583 2nd Dec 2013 8:04pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
Take it up to Greenbank 4x4 mate. I use them for anything I can't fix and they're top notch.
Post #226591 2nd Dec 2013 8:34pm
mjdronfield
I'd guess its a reluctor ring on one of the driveshafts that's not sending a signal to one of the wheel speed sensors. Car thinks the other 3 wheels are spinning so activates abs. It then realises the readings are not right, so disables abs, dsc, etc
I had the issue on my rear passenger wheel, which is also used for the speedo reading.
I posted a thread on it around the middle of September.
Worth a check........ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #226596 2nd Dec 2013 9:16pm
Dolphinboy
United Kingdom 2011 Range Rover Vogue TDV8 Atacama Sand
Look for gunge on the connectors in the ABS module. This is the first item on the canbus loop and when it throws a fault it also stops the info flow and triggers the HDC and other sensors. I had this once with all the lights on imaginable and cleaned a small spec of greeny corrosion off one connector in the ABS module and all good (see my gallery for pics)
Post #226597 2nd Dec 2013 9:19pm
