Home > Technical (L322) > TD6 starting problem
piersie
England 2003 Range Rover Vogue Td6 Epsom Green
Hello all
My Range has never been the quickest starter,in summer 3 turns of the engine until she fires up,winter 5 turns.
My mates Range (same year) half a turn summer or winter.
Any way last week she failed to start (new Bosch battery last year) so on removing fuel pipe off filter next to engine and found no fuel i bought and fitted a high pressure fuel pump. Started first time.
On reading other similar topics on forum i also replaced fuel pressure relay.
This morning she would not start so got out my Hawkeye and fuel pressure control valve is at fault, so pls can some one tell me where is the fuel control valve situated,and is it made of gold and studded with diamonds hence costing billions of squids.
Any advice much appreciated.
Cheers Piers Thumbs Up
Post #225313 26th Nov 2013 12:23pm
got this of rave,dunno how much it will cost though..
Post #225315 26th Nov 2013 12:31pm
piersie
Stan your the man , Thanks so much for that,very helpful i am in the process of ordering a couple of bits off Dan, ans will now add to the order. Nice one Stan. Thumbs Up Thumbs Up
Cheers Piers
Post #225316 26th Nov 2013 12:39pm
Thumbs Up ... - .- -.
Post #225321 26th Nov 2013 12:59pm
piersie
PM sent tp Dan. Thumbs Up
Post #225323 26th Nov 2013 1:03pm
Check the fuel pump under the N/S rear wheel
Post #225332 26th Nov 2013 1:45pm
piersie
Hi 47
I changed that last week High pressure fuel pump.
Post #225334 26th Nov 2013 1:56pm
daveturbo
injector
I had the same problem ,but after a injector leak off check one injector was bleeding off so fuel pressure was too low and would not start.May be worth a check. Mercedes AMG w207
E class Cabriolet
Overfinch L322 4.4 tdv8
1987 sierra rs cosworth 3 door white.
1985 escort rs turbo series one.
1992 sierra sapphire 4x4 cosworth red
1993 sierra sapphire cosworth 4x4 silver
1993 sierra sapphire cosworth 4x4 white
1995 ducati 916sp.
Post #227094 5th Dec 2013 12:26am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Had the same, ultimately turning on key for up to half a minute, 4 injectors later, like a different car. Not a cheap fix though !
Post #227124 5th Dec 2013 9:28am
Same happened with me. Dodgy injector. Try some injector cleaner first.
Post #227149 5th Dec 2013 11:14am
piersie
Thanks that sounds like sound advice, are we talking about a Diesel additive or is more technical ??
Would you credit it,its been starting fine for the past week but this morning as it was just a tad chillier and plenty of cranking but no firing.
Cheers Piers Big Cry
Post #227212 5th Dec 2013 6:14pm
Mr Tee
Get a bottle of the forte stuff, then diagnostic check if symptoms persist.
Post #227213 5th Dec 2013 6:21pm
piersie
Cheers Mr Tee Is that a Diesel additive.??
Post #227214 5th Dec 2013 6:24pm
Piers, it's all discussed here -> The Diesel Fuel System Cleaner Thread....
Forte comes well recommended and number one seems to be BG244. I used STP but that was just because of local availability, although it did cure a slight run on when the engine was turned off.
Post #227225 5th Dec 2013 8:12pm
piersie
Kurt thank you so much for that, i will phone Torquing Diesel tomorrow ,and as i am only 6 miles away from Bracknell will collect tomorrow. I will let you know if it sorts my problem out,but thanks for the heads up. Thumbs Up Thumbs Up
Cheers Piers
Post #227300 6th Dec 2013 1:34am
