Home > Technical (L322) > TD6 starting problem |
Needle Member Since: 07 Dec 2012 Location: Aberdeen Posts: 51 |
I had the same problem too... faulty injector .) |
6th Dec 2013 7:01am |
piersie Member Since: 18 Dec 2010 Location: Berks Posts: 97 |
Thanks for that Needle, it well could be an injector,but its not showing up any faults on my Hawkeye. |
6th Dec 2013 11:14am |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
If it doesn't get better with the cleaner then do a leak off test and you'll know. |
6th Dec 2013 1:29pm |
Kurt without appearing to be dimmer then i am already, what is a leak off test. |
6th Dec 2013 4:10pm |
