![]() | Home > Technical (L322) > TD6 starting problem |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
got this of rave,dunno how much it will cost though..
piersie Member Since: 18 Dec 2010 Location: Berks Posts: 97 ![]() ![]() ![]() |
Stan your the man , Thanks so much for that,very helpful i am in the process of ordering a couple of bits off Dan, ans will now add to the order. Nice one Stan. |
PM sent tp Dan. |
Check the fuel pump under the N/S rear wheel |
Hi 47
daveturbo Member Since: 11 Nov 2012 Location: county durham Posts: 107 ![]() ![]() ![]() |
I had the same problem ,but after a injector leak off check one injector was bleeding off so fuel pressure was too low and would not start.May be worth a check. Mercedes AMG w207
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2685 ![]() ![]() ![]() |
Had the same, ultimately turning on key for up to half a minute, 4 injectors later, like a different car. Not a cheap fix though ! |
Same happened with me. Dodgy injector. Try some injector cleaner first. |
Thanks that sounds like sound advice, are we talking about a Diesel additive or is more technical ??
Get a bottle of the forte stuff, then diagnostic check if symptoms persist. |
Cheers Mr Tee Is that a Diesel additive.?? |
Piers, it's all discussed here -> The Diesel Fuel System Cleaner Thread....
Kurt thank you so much for that, i will phone Torquing Diesel tomorrow ,and as i am only 6 miles away from Bracknell will collect tomorrow. I will let you know if it sorts my problem out,but thanks for the heads up. |
