Home > General (L405) > Turbo hose popping off
teeleh
Netherlands 2019 Range Rover Autobiography 2.0 PHEV Carpathian Grey
My turbo hose blew off my TDV6 three times and every time I had to call LR roadside assistance that calls in the AAA in order to continue my journey. The hose comes off quite deep down in the engine bay and if the engine is hot it is hard to reach. I also do not travel with spare clamps to but it back together.
Last week my Landrover dealer has installed a new hose that LR designed to prevent it to pop off during heavy load, after blowing it off for a third time. Apparently it is not showing up frequently enough to issue a recall. They just replace the hose and the clamp on cars that come in with the issue and will not actively call customers that have had this happen to their cars in the past ...
Just so you know when you lose most power and the car drops down in speed and cannot perform decent acceleration anymore that it might be this hose coming off. RR's that are part of my car timeline since I bought my first RR Classic in 1999:
On the waiting list for the RR EV MY2025 Wink
RR D250 Autobiography MY2023
RR P510e Autobiography MY2023
RR P530 LWB First Edition MY2023
RR EVOGUE Cabrio MY2017
RR P400e Autobiography MY2020
RR TDV6 Autobiography MY2016
RR TDV6 VOGUE MY2013
RR TDV8 VOGUE MY2009 & MY2006
RR TD6 VOGUE MY2004
RRC 3.9i VOGUE MY1994 & MY1992
Post #223338 16th Nov 2013 11:19am
joshydee
2002 Range Rover Vogue 4.4 V8 Stornoway Grey
Ive had this problem on my SDV8 2013 Vogue SE (bought as an ex demonstrator). Hose popped off the inter-cooler last night, AA came out and put it back on and tightened the jubilee clip as much as possible. Then the same has happened today. Strangely the hose itself seems to have been replaced before as it has a land rover green sticker on the pipe (the type of sticker when you buy a part from Land rover) with a part number. Currently waiting for a Land rover technician to come out and look it over in the next hour. Sad
Post #223529 17th Nov 2013 4:39pm
teeleh
My dealer told me both v6 and v8 are affected. The new hose is tighter on the engine block and has beteer clips. RR's that are part of my car timeline since I bought my first RR Classic in 1999:
RR TD6 VOGUE MY2004
Post #223541 17th Nov 2013 5:49pm
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
Had this on l322 at 50 miles and l405 in fact both my l405's inside 1000 miles and on a TDV8 sport , just crap factory fitment , just ask a roadside tech how many they have done , they will just smile or laugh, Clips are not good and not being tightened at the factory properly Sad Far to many gone...
Post #224648 22nd Nov 2013 7:58pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Happened on press cars too. Laughable that something so simple can't be sorted. Even the dealer could check at PDI.
Post #224740 23rd Nov 2013 10:46am
tboner001
There is a service notice that should be carried out on PDI by dealers i was told. Far to many gone...
Post #225052 25th Nov 2013 7:49am
Badger
United Kingdom 2018 Range Rover Autobiography 2.0 PHEV Carpathian Grey
Happened to a guest of mine at a shoot a couple of weeks ago
Post #237595 28th Jan 2014 8:43am
Nick Ground
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Indus Silver
Mine on the L405 actually split. Been ok since replaced. Now at 19k miles. 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
gone 17 older variants of FFRR
Post #237767 28th Jan 2014 8:06pm
