Home > Maintenance & Mods (L322) > Towing socket charger adapter - Any Experience ? |
a 3.8amp charger would take well over a day to make sure a battery was in good nick! jeepers my ctek can take 24hours to pull the flat 90ah one in my FF upto scratch and its an MXS5 unit
18th Nov 2013 9:55am |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
Better than nothing though, if you've already got one or as a cheap spare. |
18th Nov 2013 9:56am |
True in that it's good as a topper upper or trickle charger if it supports it as long as you aren't running anything else in the car at the same time FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
18th Nov 2013 10:01am |
silversurfer Member Since: 24 Oct 2013 Location: londinium Posts: 84 |
Many Thanks. |
18th Nov 2013 4:21pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8594 |
I have an old absaar charger, seems to work at charging things well enough, cant really justify 90 sheets on a nice shiny ctek.
18th Nov 2013 5:27pm |
TomC-RRV8 Member Since: 18 Sep 2022 Location: Pangbourne Posts: 77 |
Martin, Are these still available as I can't seem to find them on the forum shop? Thanks Tom Current 2011 4.4TDV8 VSE 1972 MGBGT Gone 2004 Discovery Landmark 2.5D 2003 Freelander TD4 SE |
12th Aug 2024 10:28am |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 276 |
I’m just making one of these up. I include the wiring diagram for the 12S 7pin plug below. The grey 7 pin plugs are available on Amazon as is a 2.5M CTEK extension cable which can be modified/wired into the plug.
12th Dec 2024 9:43pm |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 688 |
Most people goo for a C-Tek 5.0 charger then into the mains. You’ll need a hefty charger because of the battery size. I bought one of these plugs 5 yrs ago, racking piece of kit & well worth the money. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice! Alfa Romeo Giulietta Just one Montesa now, 349 White Wonder Austin A40 Farina MK2 1975 Morris Marina 1.8TC 1973 Honda CB250 K4 |
13th Dec 2024 8:25am |
