Home > Maintenance & Mods (L322) > Towing socket charger adapter - Any Experience ?
Page 3 of 3 <123
a 3.8amp charger would take well over a day to make sure a battery was in good nick! jeepers my ctek can take 24hours to pull the flat 90ah one in my FF upto scratch and its an MXS5 unit Smile
from personal experience those small cheap chargers are only really good for small sub 1.6litre petrol cars or motorbikes really. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #223624 18th Nov 2013 9:55am
Martin
Site Admin
Better than nothing though, if you've already got one or as a cheap spare. Wink
Post #223625 18th Nov 2013 9:56am
True in that it's good as a topper upper or trickle charger if it supports it as long as you aren't running anything else in the car at the same time Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #223627 18th Nov 2013 10:01am
TugRR
^^ Thanks for the info, Martin. It's just to keep it topped up over winter and during the week is only used for short trips for Jnr Taxi Service Rolling Eyes
Thumbs Up Where do you go after one of these . . . ?
Post #223640 18th Nov 2013 12:02pm
silversurfer
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Orkney Grey
Alistair wrote:
Yes - you can wire up a battery to the tow socket & then open the doors.
Obviously, the cabling is too thin to try starting the car, but at least it will let you unlock the cat to open the bonnet.
Many Thanks.
Post #223689 18th Nov 2013 4:21pm
I have an old absaar charger, seems to work at charging things well enough, cant really justify 90 sheets on a nice shiny ctek.
like the idea of martins adaptor Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #223705 18th Nov 2013 5:27pm
TomC-RRV8
Martin wrote:
Yes they do Smile
You can also modify the charger's connector to make it non latching:
http://www.disco3.co.uk/wiki/Remove_lock_button_from_CTEK_plug
Martin,
Are these still available as I can't seem to find them on the forum shop?
Thanks
Tom Current
2011 4.4TDV8 VSE
1972 MGBGT
Gone
2004 Discovery Landmark 2.5D
2003 Freelander TD4 SE
Post #697871 12th Aug 2024 10:28am
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
I’m just making one of these up. I include the wiring diagram for the 12S 7pin plug below. The grey 7 pin plugs are available on Amazon as is a 2.5M CTEK extension cable which can be modified/wired into the plug.
 TDV8 4.4 2012
Post #706735 12th Dec 2024 9:43pm
Fox889
andyleeds wrote:
This probably sounds stupid but what does the other end plug into? The mains?
Most people goo for a C-Tek 5.0 charger then into the mains. You’ll need a hefty charger because of the battery size. I bought one of these plugs 5 yrs ago, racking piece of kit & well worth the money. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #706753 13th Dec 2024 8:25am
Page 3 of 3 <123
