Home > Group Buys > flip keys [New Order Oct 2014] |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
okay let's start with the first problem you say you can't pair a key with the car, is the key going through the sync process, after you release the buttons do you get the three long flashes on the l e d, this tells you you have gone through the process V8 facelift Range Rover Autobiography 22" wheels.
9th Nov 2013 12:38pm |
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 |
ok pressed unlock,when led started quick flashing pressed lock three times.I have followed this procedure a lot of times but never got the three long flashes on the led |
10th Nov 2013 5:14pm |
Just got my key working. Had to remove the "blank" transponder chip first and stick my old one in to get the car to see it. Relearned all three keys and all working fine now.
10th Nov 2013 7:46pm |
right, you need to practice this, they all sync as i test them before they go out... forget doing it in the car, do it indoors ok... with the remote in your hand with the blade at the top, wait a few mins after pushing of any button so the sync process can start clean, as before hold down bottom button and keep pressed down through out the sync process, led starts to flash quick...now try 3 long presses of the top button,after the third press let go of the bottom button..if you see the led flash at all during the pressing of the buttons stop as its failed. some keys like to have 3 quick presses and some like 3 long presses but i have not come across a key that does not sync.. dave V8 facelift Range Rover Autobiography 22" wheels. 1976 Harley Davidson Iron Head Sportster |
10th Nov 2013 9:04pm |
Thanks Dave for your time.I will retry and let u know |
11th Nov 2013 8:42am |
Dom Member Since: 11 Nov 2013 Location: Watlington, UK Posts: 2 |
Hi Daveo, I have a 2003 L322 Range Rover and would like a new style flip key. Could I order it from you and you program it? I am not far from London so no probs to come into town. I am not confident about taking my old style key apart myself. Thanks. |
11th Nov 2013 6:07pm |
pm sent.. V8 facelift Range Rover Autobiography 22" wheels.
11th Nov 2013 8:19pm |
Dave have tried to sync key.so switched on/off ignition key out.pressed on flip key unlocked button and by the time led started quick flashing I presses lock button 3 times,bit longer press as u suggested and when released unlock button I took 3 led longer flashes but buttons of flip key are neither locking or unlocking car? |
13th Nov 2013 6:14pm |
hi so the key has gone throght the sync process, you got the 3 long flashes on the led but it never locked and unlocked the car...
13th Nov 2013 6:26pm |
Yes got the the 3 longer flashes.is there any way to Find out if 315mhz or not. |
13th Nov 2013 9:18pm |
you will need to find out from the dealer with your vin, there a few people on here that can do that for you...
13th Nov 2013 9:44pm |
U are right I cut the blade |
13th Nov 2013 10:38pm |
well lets hope we can get it working as i can not return it if it has been cut,
13th Nov 2013 10:51pm |
kruger2002 Member Since: 19 Jul 2013 Location: Newbury Posts: 70 |
Just to say finally got my key cut. Great service via post from a guy in Ashton.
14th Nov 2013 12:05am |
