Home > Group Buys > flip keys [New Order Oct 2014]
Sign Up
(28)
(58)
(18)
User Registered Confirmed
Stephen.12531st Aug 2013 1:19pm
andyleeds6th Sep 2013 5:53pm
DTaylor21st Sep 2013 4:12pm
Elduke7th Oct 2013 9:31pm
daveo26th Feb 2014 11:08pm
gregh14th May 2014 8:33pm
gezzer152013th Aug 2014 2:44pm
Bunchy1001st Nov 2014 2:08am
dhallworth16th Nov 2014 11:26pm
tony6623rd Jan 2015 10:53pm
47p217th Feb 2015 7:01am
Stomer Drl9th Apr 2015 7:19am
hex8th Jun 2015 8:38pm
J9022nd Jul 2015 7:57pm
socialrover17th Oct 2015 12:48pmsocialrover is confirmed
dolph3418th Oct 2015 8:21pmdolph34 is confirmed
freeforme7728th Dec 2015 5:44pmfreeforme77 is confirmed
prayer16312th Feb 2016 12:22pmprayer163 is confirmed
TrumptonDave15th Jun 2016 10:30amTrumptonDave is confirmed
kz355130th Aug 2016 8:20pm
Krams15th Oct 2016 5:58pm
tcmnorcal6th Oct 2017 1:21pm
seaneb7th Nov 2017 10:19pm
Quiff6th Aug 2020 5:57pm
abalanos5th Feb 2021 4:50pm
Steaky18th Feb 2022 10:28am
its me5th Aug 2022 12:20pm
yomchi8613th Nov 2023 9:00pm
Baldrick563528th Aug 2013 9:22pm
Mustard28th Aug 2013 10:27pm
MrP29th Aug 2013 3:21pm
willowzn30th Aug 2013 9:10pm
andy18030th Aug 2013 10:09pm
flipflop1st Sep 2013 11:36pm
RichTD66th Sep 2013 9:17pm
Tallsaj9th Sep 2013 9:08pm
glennhoward11th Sep 2013 6:58pm
kruger200218th Sep 2013 10:45pm
Simes19th Sep 2013 5:52pm
geordiefella8th Dec 2013 2:30pm
redshovel3rd Jan 2014 8:43pm
jak4807th Jan 2014 6:07pm
dazt_8515th Jan 2014 10:24am
cliffy8th Feb 2014 6:44pm
Winchester1018th Feb 2014 8:50pm
rej12th Feb 2014 7:47pm
mick-ne24th Feb 2014 10:22pm
steviebabes25th Feb 2014 9:19am
rads26th Feb 2014 1:47pm
dba1128th Feb 2014 6:37pm
RRIII5th Apr 2014 6:40am
Needle12th Jul 2014 7:48pm
jj29081st Sep 2014 7:44am
docjones23rd Sep 2014 9:31pm
Smegordead29th Sep 2014 6:55pm
Turnover30th Sep 2014 12:43pm
Roofer1st Nov 2014 6:43am
comports2nd Nov 2014 5:37pm
mgbgtv826th Nov 2014 7:46pm
Jaipo7th Dec 2014 7:40pm
chex3rd May 2015 10:26pm
shinchan2nd Jun 2015 4:05pm
Boydonegood6th Jun 2015 6:42am
DannyH8th Jun 2015 10:52am
Billydun3416th Aug 2015 9:20pm
zetjester14th Nov 2015 5:40pm
Mike.Boro18th Nov 2015 4:20am
davethomas8329th Dec 2015 2:24pmdavethomas83 is confirmed
MCM665th Jan 2016 10:37pm
Ohwhatalad7th Jan 2016 8:46pm
454awg27th Jan 2016 7:31am
Ollie_24726th Feb 2016 4:07pm
Big Tings11th Jun 2016 6:09pm
CY8816th Jun 2016 12:41pm
Wylie6619th Jun 2016 8:19pm
MatsonTAS20th Jun 2016 6:57pm
Donnor26th Jun 2016 5:28pmDonnor is confirmed
ErwinS19th Feb 2017 8:12pm
Rewmer24th Feb 2017 3:57pm
alfapat25th May 2017 6:09am
nebc10028th May 2017 7:54pm
L322 Newbie27th Jul 2017 6:18am
easylife10312th Oct 2017 7:16pm
biggirly119th Sep 2018 10:23pm
haaris19th May 2020 4:08pm
Mane_Ugle11th Oct 2021 9:52pm
ebajema28th Aug 2013 6:22pm
markpr28th Aug 2013 7:16pm
cstowe212028th Aug 2013 9:37pm
AKIS29th Aug 2013 1:24pm
jwclements12nd Sep 2013 2:36pm
duck109816th Sep 2013 10:15pm
Scottrx7tt16th Nov 2013 3:10pmScottrx7tt is confirmed
RangeK1D5th Mar 2014 11:20amRangeK1D is confirmed
christoforos7th Apr 2014 1:34amchristoforos is confirmed
markskyline20th Oct 2014 10:51ammarkskyline is confirmed
Kaj28th Feb 2015 5:36pmKaj is confirmed
Ian c229th Dec 2015 8:58pmIan c2 is confirmed
rar11016th Apr 2016 11:23pmrar110 is confirmed
beaudog1111th Jun 2016 8:34pmbeaudog11 is confirmed
csufy27th Feb 2017 3:40pm
Lukie24th Jun 2017 10:18am
jonasserra12th Jul 2017 11:07am
muddycharles3rd May 2024 3:52pm
Page 11 of 36 <123 ... 101112 ... 343536>
daveo
if you just put the original key into the ignition with out the guts it will not work for sure and no you will not cause any issues...give it a go V8 facelift Range Rover Autobiography 22" wheels.
Post #220204 1st Nov 2013 5:14pm
daveo
mustard can you take a photo of your to keys, it will have to be a good quality and close up.
does the new key slide into the ignition smoothly
just want to check when you put the new key in,do you get the click from the ignition V8 facelift Range Rover Autobiography 22" wheels.
Post #220205 1st Nov 2013 5:20pm
Mustard
Ok so took the guts out of the original key, went out to the motor and put the key into ignition, no clicks as expected but it did turn the ignition to position 1, no further as its solid at that position. I put it all back together and tried again, everything back to normal again.
The flip key wont turn at all, proper solid. Ill go fetch the keys, photo them and put them up here however I can only use my iphone to take pics as thats all I have Laughing
Post #220215 1st Nov 2013 6:28pm
Mustard
Key slides into ignition with no issues at all, I only get the click from the ignition if the transponder is in the flip key
Hard to get the lighting right for the pics, took about 20 in different settings etc
Ok Ive edited the post and re done the pics to make sure they are both the same sides of the blades next to each other
Post #220220 1st Nov 2013 6:52pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
To me it looks wider and the groove near the tip looks straighter?
Shocked
Post #220222 1st Nov 2013 7:01pm
ebajema
Synced on the first try, now just need to do the blade as the old transponder is also on place.
Then need to glue the case closed Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #220231 1st Nov 2013 7:44pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Mustard wrote:
That looks like a terrible cut of the key - it looks wider and the top end (the final straight bit) is longer on the cut - I think the cutting machine (or operator) wasn't set up right.
Post #220316 2nd Nov 2013 12:12pm
daveo
the key was cut by a baffoon, the cut is far to long, on the ignition lenght is critical, all you can do with that is take some of the end of the key to get the tip and the start of the cut lined up.. V8 facelift Range Rover Autobiography 22" wheels.
Post #220338 2nd Nov 2013 1:56pm
Mustard
OK so its a turd cut, getting somewhere Very Happy
The question is now where do I go from this ?
Do I really want to entertain this guy in any fashion after he has just destroyed my key ? Rolling Eyes
Post #220341 2nd Nov 2013 2:35pm
stormindes
United Kingdom 2003 Range Rover Vogue Td6 Oslo Blue
Hi Daveo, do you have any 'spare' flip keys left over? Only asking as I have an 03 Vogue with only one key and I would like to increase my chances of being able to use it when I eventually loose that one key Laughing
If not, when are you doing another batch and how many orders do you need?
And lastly, can I confirm that you need the EWS in order to supply an additional key? I.E. you need the EWS to program a new chip to the new key???
Cheers Thumbs Up Yes I was there but I wasn't directly responsible for that particular part because I was way over there in the corner with my back turned and anyway I wasn't even supposed to be here today
Post #220343 2nd Nov 2013 2:50pm
AKIS
2004 Range Rover Vogue Td6 Cairns Blue
sync flip key
ok guys major problems hers.Key cut and transponder in but under no way is syncd.Procedure i follow
insert old key into lock fm 0 to i withon 5 secs and then out.
in flip key press the unlock fr 15secs and during this period press 3 times lock
procedure should be the one since i resyncd the old type key but under no way the flip key
also when i insert the flip key in lock i donot hear the unlocking sound/not turning to position.hever normally lock/unlock doors
Any ideas please???????
Post #221650 8th Nov 2013 2:15pm
AKIS
sync flip key
believe my above message bit confusing so reposting
Flip Key cut and transponder in.Tried today to sync but same not possible.Procedure i followed as foll"
1 insert old key into ignition turned fm 0 to I and back to 0 withon 5 secs and then key out.
2.pressed flip key unlock button fr 15secs and during this period pressed 3 times lock button
and should be the right since i resyncd the old type key but under no way flip key can be syncd.
Also when i insert the flip key in ignition lock i donot hear the unlocking sound/key is not turning to any position.Hever flip key is inserted in handle door locks and normally lock/unlock doors manually
What i am doing wrong/Any ideas please???????
Post #221654 8th Nov 2013 2:45pm
daveo
hi mate,,, ok try the sync process in doors not in the car so you get it right, press the bottom key it will flash then starts to flash fast,keep it pressed,,, at this point you then press the top button 3 times, do the 1,2,3 mississippi thing then relese both buttons..you are looking for the 3 long flashes, get this right then try in the car... V8 facelift Range Rover Autobiography 22" wheels.
Post #221679 8th Nov 2013 5:44pm
daveo
with the chip,please make sure there is not an unprogramed one in there, i thought i removed them all but i did over look a few, hold the chip near the ignition you should here the click,if so pop the new key in and try turning but dont start just put ignition lights on then off... V8 facelift Range Rover Autobiography 22" wheels.
Post #221681 8th Nov 2013 5:48pm
AKIS
Good day Dave.Thanks your last.Yes unprogrammed chip was in.Took it out and now flip key unlocking steering wheel/turning to position I
Problem is that cannot be syncd?????Pressing unlock button,after old key fm o to i then back to o and out of ignition.Press unlock button and as soon as light starts quick blinking pressing 3 times lock button but nothing Have tried even against chronometer so to be exact on required secs??????
Supposing that i am doing sync procedure right can be any other reason that is not syncd???
Post #221813 9th Nov 2013 10:21am
