Home > Technical (L322) > Help re. Alternator
Page 3 of 4 <1234>
you switched off fairly quickly so probably not... ... - .- -.
Post #209766 12th Sep 2013 12:03pm
Simusmaximus
Wales 2004 Range Rover Vogue 4.4 V8 Java Black
I hope not Stan as this is getting worrying to say the least.
Could I be unlucky in it being a dud new alternator?.
The company I bought it from have agreed to send me out a replacement, which is totally decent of them.
I will give it a try and cross everything!. Laughing "I got him boxed in like a turtle's pecker!".
Post #209771 12th Sep 2013 12:22pm
Don't cross any wires Whistle Whistle
Post #209816 12th Sep 2013 2:29pm
Simusmaximus
Rolling with laughter "I got him boxed in like a turtle's pecker!".
Post #209829 12th Sep 2013 2:45pm
Simusmaximus
Quick update guys.
The second new alternator arrived today, which I fitted with everything except wiring crossed and bingo!.
No more battery light, no more error messages, brilliant.
So the first new alternator was in fact faulty.
I probably could have done without the new battery but after the strain put on the old battery and with winter coming up, I am unlikely to regret the investment in the long run.
I would like to thank everyone who posted in this thread with suggestions and help.
That's what makes this forum great. Thumbs Up
I am a very happy bunny tonight. "I got him boxed in like a turtle's pecker!".
Post #210105 13th Sep 2013 5:38pm
magic.. Thumbs Up ... - .- -.
Post #210115 13th Sep 2013 6:41pm
Sorted, could a MOD please lock this thread Laughing Laughing Laughing
Post #210137 13th Sep 2013 8:21pm
Think yourself lucky you changed the alt twice on a petrol not a TDV8 Rolling Eyes Shocked Neutral
Post #210170 13th Sep 2013 11:31pm
ebajema
Well done mate, I'm glad it is sorted !!! MY 2010 5.0 SC Galway green and sand interior!!
Post #210178 14th Sep 2013 7:31am
Simusmaximus
Thanks gents.
To be honest, the first time I changed it was a bit scary, but second time it was quite straight forward because I knew exactly the procedure to do it.
Just a side note for others of you that need to do this on a 4.4 v8, there is no need to remove the radiator.
As long as you remove:-
Disconnect battery.
Coolant from system ( careful if it's still a bit hot )
Air intake pipe ( runs from air filter and MAF sensor to top of engine )
Viscous fan and coupling
Radiator fan cowling
Top radiator hose ( this connects in 3 places, water pump, alternator and rad ) remove from all 3 and put out of the way.
Remove belt tension
Remove serpentine belt
Remove belt tensioner mechanism completely ( dual wheel pulley type in this case )
Take off alternator wiring
Undo alternator retaining nuts x6
With a little wiggling and pulling, out she came, followed by a little coolant.
There was plenty of room to pull the alternator out and pivot upwards and out in front of the rad. Thumbs Up "I got him boxed in like a turtle's pecker!".
Post #210216 14th Sep 2013 10:52am
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
had a similar issue last year..if the alternator goes the likely hood of the battery failing concurrently are high...
you may find that the battery has sulphonated...winter will tell.. 2011 4.4 TdV8 Nara Bronze
Post #210324 14th Sep 2013 11:20pm
was the alt a new bosch unit or a copy? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #210518 15th Sep 2013 10:45pm
Simusmaximus
Sadly, it's a copy, not a Bosch but for the money and not being 100% at the time that it was the alternator, I decided to give it a go.
Now I know it was infact at fault, I will just see how long it lasts to know wether or not it was worth it. "I got him boxed in like a turtle's pecker!".
Post #210596 16th Sep 2013 6:53pm
I had a new copy. lasted 4 weeks before the bearings packed in! ended up with a recon bosch in the end. a few places round here will overhaul for about £80. I've got an old one I need to have reconditioned and then put on eBay. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #210598 16th Sep 2013 6:56pm
Simusmaximus
Cheers Rob, that really fills me with confidence!. I hope mine lasts a bit longer than 4 bloody weeks!. "I got him boxed in like a turtle's pecker!".
Post #210599 16th Sep 2013 6:59pm
Page 3 of 4 <1234>
