![]() | Home > Technical (L322) > Help re. Alternator |
Not sure I would read too much into the voltage readings obtained from the "hidden menu", from what I have read on here they tend to be not too accurate.
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 ![]() ![]() |
Nah, at this stage of battery problems the alarm setting off will surely be caused by battery voltage dropping below a set point. I had this nocturnal nightmare when my FSR was draining the battery, only thing on mine, I could only stop it by physically disconnecting the battery. |
Simusmaximus Member Since: 06 Mar 2013 Location: South Wales Posts: 60 ![]() ![]() ![]() |
Cheers nicedayforit, I am trying to stay optimistic about this. I don't know how old the battery is either, so the latest round of trauma may well have damaged it beyond use. "I got him boxed in like a turtle's pecker!". |
Morning paneldamage, I left mine unlocked.
It does seem that when the alternator fails on an FFRR and the car continues to be used until the battery is dischages and the car stops that it results in the battery, however old, being rendered u/s.
IWC1 Member Since: 11 Jan 2013 Location: suffolk Posts: 18 ![]() ![]() ![]() |
I had the same problems last year, first the battery red light which was indeed a knackered Alternator.
What would an overcharging alternator do to a battery?.
I had a duff regulator on an alternator (Bosch and easily replaceable) on a car years ago. I found out something was wrong when the battery got "cooked". First I thought it was the brakes (I had been driving quite spirited just before) but when I opened the hood (the smell was not coming from the brakes) I noticed the battery starting to melt at the top and the smell was clearly more plasticky then.
Well I just went and bought a new battery and the problem is still there!. Looks like the new alternator I put on is flumped!.
Do you have any auto electricians in the neighbourhood ?? To get the alternator and battery and wiring tested ??
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35611 ![]() ![]() |
i gather when you fitted the new battery you turned the steering wheel fully left then right..
Hi Stan, I did do the left right reset with the steering wheel. I went straight around to the battery And I could smell a strong sulphur like smell, rotten eggs to be precise. This is with a new alternator and brand new battery. I didn't want to do any damage so I shut it off and disconnected the battery to be safe. "I got him boxed in like a turtle's pecker!". |
that smell is battery acid boiling ...
Will I have damaged the battery now?. "I got him boxed in like a turtle's pecker!". |
