![]() | Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 ![]() ![]() ![]() |
Any idea when it will be available to all? |
We are delivering to Britpart in the coming weeks. They will require another couple of days to process and get the units out to the dealers.
Al Hornby Member Since: 19 Mar 2013 Location: Horsham West sussex Posts: 18 ![]() ![]() ![]() |
Will the current module be phased out in preferance of the new BT module when its generally available?
Unfortunatly I couldnt find Britpart at Billing over the weekend, so will have to now buy one of these tools from one of their distributors.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35535 ![]() ![]() |
best to google and then ring up but Graham [AGIS] found this one, http://www.island-4x4.co.uk/advanced_searc...=0&y=0 ... - .- -.
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 ![]() ![]() |
Hi Steve and all, thought it worth posting my query on here, the answers may be useful to others...
Hi PD,
"Also I am using the tool with the handbrake off and the engine running, as recommended"
Sorry.Must learn to read more thoroughly |
Steve, is it not better to discuss the problem/likely causes on the forum? Might save GAP some repeat emails if its something that all users should know and may come across in their future use?
Hi PD,
Yes, that is potentially a problem - though most major components in a system are checked for connectivity (similar to a light check) and if no connectivity is detected that in itself becomes a fault. Diagnostic tool is a bit of a misnomer because diagnostic systems are fault code readers and actually do not do any real diagnostic testing on their own: all they do is deliver pre-defined fault codes from the various ECUs to the user. You only do real diagnostics when you manually move a stepper motor, turn on a light, etc. through the 'check component' functions (which the IIDTool can do). Your problem does sound like a connectivity issue, but it is probably more simple than you are making it out to be. If the ECUs you mention all had no connectivity, your car would be immobile or at least running so poorly that you'd notice. It is likely a poor OBD connection or similar. We'll work through it with you. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
dalziel Member Since: 10 May 2013 Location: Harrogate Posts: 57 ![]() ![]() |
You have a pm |
srpara Member Since: 03 Oct 2013 Location: moray Posts: 115 ![]() ![]() ![]() |
did you get round to testing it??? |
