![]() | Home > In Car Electronics (L322) > Retrofiting a Bluetooth ULF Module |
Ash_vogue Member Since: 25 Mar 2013 Location: Uk Posts: 14 ![]() |
Ok thank you, what it wiki and where can I find it! Thank you |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35634 ![]() ![]() |
wiki link is under the fulfat.com banner (top right of page) ... - .- -.
Thank you, I will have a look |
StevePg Member Since: 13 Jun 2013 Location: Perugia Posts: 6 ![]() ![]() |
Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193 ![]() ![]() ![]() |
Ok that's great, thank you, I've also noticed that I have the voice module under that sat nav unit, what do I do with this?
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7909 ![]() ![]() ![]() |
You should not need either the old phone module or the telephone module (TCU).
Thanks guys, I've managed to wire it all in, it wasn't to bad to do after reading this forum. Just going to try and get navcoder now to do the voice activation.
strega Member Since: 09 Oct 2013 Location: surrey Posts: 2 ![]() ![]() ![]() |
I tried the pin changes yesterday but could not find a wire in 52 to put into 19, any thoughts? If I turn the car on and select phone I get 'activate phone'. I have read that I need to pair it but am confused as some say use the button on the steering wheel others elsewhere! My car is fitted with a phone in the armrest if it matters. Also do I need to bypass the voice module or not, as getting conflicting advice there? |
Hi mate.
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I'm just about to do this install. I've bought an 8th gen ULf and have re-pinned the plug. Went to BMW yesterday and was quoted £75 for the antenna, cable and microphone. |
I had a quick look on the bay of e, and second hand, the antennas are still between £30 and £40 odd, so £75 new for that and the cable and microphone seems pretty good.
Ordered the antenna and mic. Arriving in a couple of days. Did you say that the ulf could be plugged in and paired without these items? I wouldn't mind trying it to see if it works.
