Home > Technical (L322) > Max Aircon - No Aircon On RHS SOLVED! |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
Gonna start with a regas - IIDTool is telling me the evaporator temp was 23 deg - presume this should be close to zero and gas pressure was 10 (presume this is in PSI) - tested on running system with max aircon on for 10 mins |
5th Jun 2013 8:57pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
If you have chilled air coming out of one set of vents it tends to suggest the cooling is working.
6th Jun 2013 7:28am |
Does anybody know how to get at the TEMP SENSOR(s) to clean? |
6th Jun 2013 7:55am |
It's located behind the small grille on the upper facia panel.
6th Jun 2013 8:20am |
There is chilled air comming out but pretty sure its not 4 degs |
6th Jun 2013 8:21am |
You need to measure right up against the grille, I use a probe thermometer pushed into the grille opening.
6th Jun 2013 8:28am |
Thanks do you think an air gun blast may clean it without dismantling? |
6th Jun 2013 8:45am |
No I'm afraid not. The dirt tends to get compacted overtime and more or less has to be scrapped off.
6th Jun 2013 8:58am |
IIDTool will give you a live reading from that sensor .... under 'cabin temp' |
6th Jun 2013 9:48am |
Had system regassed today by my local 'specialist' - now perfect, IIDTool reports pressure of around 15-16 so although it was low it wasn't too bad and most importantly the evaporator now shows 3.2 degrees.
7th Jun 2013 11:49am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
result ..now all we need now is some hot weather.. ... - .- -.
7th Jun 2013 11:51am |
Its lovely and hot here in Hereford (except of course in my car where its positively arctic) |
7th Jun 2013 11:53am |
you'll have rain soon cos its raining here in swindon. ... - .- -.
7th Jun 2013 11:54am |
