![]() | Home > Technical (L322) > Max Aircon - No Aircon On RHS SOLVED! |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Gonna start with a regas - IIDTool is telling me the evaporator temp was 23 deg - presume this should be close to zero and gas pressure was 10 (presume this is in PSI) - tested on running system with max aircon on for 10 mins |
If you have chilled air coming out of one set of vents it tends to suggest the cooling is working.
Does anybody know how to get at the TEMP SENSOR(s) to clean? |
It's located behind the small grille on the upper facia panel.
There is chilled air comming out but pretty sure its not 4 degs |
You need to measure right up against the grille, I use a probe thermometer pushed into the grille opening.
Thanks do you think an air gun blast may clean it without dismantling? |
No I'm afraid not. The dirt tends to get compacted overtime and more or less has to be scrapped off.
IIDTool will give you a live reading from that sensor .... under 'cabin temp' |
Had system regassed today by my local 'specialist' - now perfect, IIDTool reports pressure of around 15-16 so although it was low it wasn't too bad and most importantly the evaporator now shows 3.2 degrees.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35522 ![]() ![]() |
result |
Its lovely and hot here in Hereford (except of course in my car where its positively arctic) |
you'll have rain soon cos its raining here in swindon. ... - .- -.
