Home > Maintenance & Mods (L322) > Brake Disc Change |
I need to change my discs & pads, pads I've done before but never done discs before (on any car).
13th May 2010 2:29pm |
I've always gone the other way, cheap pads = soft pads = one replaces the pads rather than the discs. Not had a problem with glazing I don't think, if I even knew how to tell! I've had 28K out of these britpart pads which I thought was reasonable and there's a 3mm step each side on the disc, LR say replace the disc at 0.6mm wear each side (1.2mm overall). But I don't happen to money. |
13th May 2010 3:29pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Dan,
13th May 2010 4:27pm |
DeltaC Member Since: 22 Mar 2010 Location: Aberdeenshire Posts: 148 |
Make sure you clean both surfaces of the discs with brake cleaner before you fit them (Its a lot easier).
13th May 2010 5:14pm |
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 |
If you are replacing the rears, just make sure you back off the handbrake shoes a long way, otherwise they will drag when pulling the disc off and you may damage the retainers.
13th May 2010 7:24pm |
StevieH Member Since: 05 Feb 2009 Location: Cumbernauld, Lanarkshire Posts: 117 |
Dan
13th May 2010 8:58pm |
I contemplated doing a "how to" when I changed mine. I was half way through before I realised I'd forgot to take any pics! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
13th May 2010 10:53pm |
jope Member Since: 04 Apr 2009 Location: Reinsvoll Posts: 43 |
Hi dan
13th May 2010 11:40pm |
Thanks guys, so basically there are no major pitfalls to watch for? I know in the past I've bought pads but didnt realise one needed to buy guide pins too etc.
14th May 2010 8:38am |
Island 4x4 have some Drilled & Grooved discs (x2) for 59.99 is there a performance increase over standard? Or do they just resist glazing and brake fade?
17th May 2010 2:10pm |
Ordered everything from Island, £150 inc P&P:
27th May 2010 1:31pm |
McSwerve Member Since: 20 Jan 2010 Location: Bedfordshire Posts: 25 |
I for one will be interested to see how you get on. As my rears are squeeling at the moment.
28th May 2010 11:39am |
I was going to to change the H/B Shoes but have you seen how expensive they are!? Oddly enough my hb works fine if the weight of the car is rolling backwards, but next to useless if forwards. This will be the ideal time to investigate what exactly is occurring. Dan |
28th May 2010 11:56am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Your hand brake will most likely need readjusting but I can't see why the shoes need to be replaced , if you think about it really is just a small drum brake inside the rear disk and never really gets any wear unless you drive with the hand brake on and that is pretty unlikely unless the warning light switch broken. Mind you if you are in there already I guess it wont hurt either . 2008 MY Supercharged
28th May 2010 12:17pm |
