![]() | Home > Maintenance & Mods (L322) > Brake Disc Change |
I had the rear discs and pads changed today, £50, not bad. Now Vented, drilled & groved front and rear. |
DeltaC Member Since: 23 Mar 2010 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
I did my front discs on Monday evening and rear discs last night. Took about 45mins per side, from start to finish. Fairly straight forward. If you do it, make sure you have new wear sensors as they seem to have a habit of breaking when they are coming out. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35655 ![]() ![]() |
was this in a garage or did you do this yourself...btw where did you get the bits dan? ... - .- -. Y. O. L. O. . |
still very interested in your very competitive cost for the pads/discs dan ... - .- -.
Soz fella, didn't see your post there.
cheers dan, i was silly in thinking you paid £50 for all the bits and fitting on the fronts...i have so much to learn about the 'not so' cheap costs that the FFRR ensues... ... - .- -.
I doubt there are many cars you can do a complete brake change for £150, and labour is labour... As long as you stay away from the dealerships! ![]() |
i have an advantage where my eldest is a qualified mechanic and still lives at home ...tech on tap ... ... - .- -.
To be fair I was all up for doing the discs myself, but couldn't get the |
Just some pics of my discs after about 1000 miles. (This was with new pads too) Still impressive stopping power.
marques.a Member Since: 17 May 2021 Location: Belo Horizonte Posts: 6 ![]() ![]() |
Sorry to resurrect this topic! In search of releasing my clinging disk, I arrived at this topic.
