Home > Maintenance & Mods (L322) > Brake Disc Change
Page 1 of 5 12345>
dan_uk_1984
Brake Disc Change
I need to change my discs & pads, pads I've done before but never done discs before (on any car).
I can follow the instructions on RAVE but are there any tips or anything I need to look out for? Whilst I'm there I'll probably do a fluid flush too.
I'm going for generic parts because I'm tight! Got it down to about £100 in Discs and £40 in Pads, plus whatever brake fluid costs these days.
Dan
Post #18180 13th May 2010 3:29pm
Vogue
not related to fitting the discs and pads but related to quality of parts.
IMHE You can get away with pattern / cheap discs but always go for quality pads, especially if you want to maintain braking efficiency. The better pads are harder and bite more into the disc and give good braking. Cheap pads are soft and can lead to glazed discs which results in not good stopping power.
Post #18181 13th May 2010 4:24pm
dan_uk_1984
I've always gone the other way, cheap pads = soft pads = one replaces the pads rather than the discs. Not had a problem with glazing I don't think, if I even knew how to tell!
I've had 28K out of these britpart pads which I thought was reasonable and there's a 3mm step each side on the disc, LR say replace the disc at 0.6mm wear each side (1.2mm overall). But I don't happen to Censored money.
Post #18182 13th May 2010 4:29pm
Andy
Dan,
it's an easy job to do. I bought my discs and pads off eBay and they are great quality. The pads are mintex and the discs are from an OE supplier (the name escapes me now but they have a website and supply only LR parts)
front discs and pads totalled £65 and the rears were £60. He had a "make offer" function when I bought them , so I got delivery thrown in.
I've fitted loads over the years and in previous occupations, so I know cheap discs and pads when I see em.
http://cgi.ebay.co.uk/RANGE-ROVER-L322-REA...5d27d769f4
http://cgi.ebay.co.uk/RANGE-ROVER-L322-FRO...1168wt_722 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #18184 13th May 2010 5:27pm
DeltaC
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
Make sure you clean both surfaces of the discs with brake cleaner before you fit them (Its a lot easier).
Apply a coating of Copperslip on the hub where it mates with the new disc so they don't corrode together and become difficult to remove the next time.
Even though you will probably not need to remove the lower pin on the caliper, do it anyway to make sure it is clean and well lubricated...
Post #18189 13th May 2010 6:14pm
SGW
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
If you are replacing the rears, just make sure you back off the handbrake shoes a long way, otherwise they will drag when pulling the disc off and you may damage the retainers.
Stewart.
Post #18199 13th May 2010 8:24pm
StevieH
Dan
How about one of your how to's when your done. I struck lucky and got mine replaced under VIP scheme but with my heavy right foot will probably do them again next year. Thumbs Up
Post #18203 13th May 2010 9:58pm
Andy
StevieH wrote:
Dan
I contemplated doing a "how to" when I changed mine. I was half way through before I realised I'd forgot to take any pics! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #18208 13th May 2010 11:53pm
jope
Norway 2003 Range Rover HSE Td6 Java Black
Hi dan
As I know you also sometimes visit rangerovers/forum...
here's a detailed description. Nothing to worry about, about same job as doing brake pad's, but just remember to do the discs with brake cleaner before mounting them.
http://rangerovers.net/forum/viewtopic.php...ilit=rotor
Post #18209 14th May 2010 12:40am
dan_uk_1984
Thanks guys, so basically there are no major pitfalls to watch for? I know in the past I've bought pads but didnt realise one needed to buy guide pins too etc.
I'll order the bits at the end of the month, thanks for the links Noddy!
I'll have a go at taking some pics for a guide, thanks for the heads up on cleaning the disc first Delta.
Dan
Post #18214 14th May 2010 9:38am
dan_uk_1984
Island 4x4 have some Drilled & Grooved discs (x2) for 59.99 is there a performance increase over standard? Or do they just resist glazing and brake fade?
D
Post #18375 17th May 2010 3:10pm
dan_uk_1984
Ordered everything from Island, £150 inc P&P:
1 x Front Brake Disc Drilled & Grooved (2) L322 02-05 DA4609 (DA4609) = £59.99 Inc. Vat
1 x Rear Brake Pad Set Range Rover L322 02-05 SFP000120 (SFP00120) = £16.99 Inc. Vat
1 x Rear Brake Disc Drilled & Grooved (2) L322 02-05 DA4610 (DA4610) = £48.99 Inc. Vat
1 x Front Brake Pad Set (Mintex) Range Rover L322 02-05 SFC500050 M (SFC500050 M) = £24.99 Inc. Vat
Sub-Total: £150.96
Shipping: £0.00
Total: £150.96
I'll do the job this weekend so I'll do some photo's to try and get a guide together.
Post #18919 27th May 2010 2:31pm
McSwerve
I for one will be interested to see how you get on. As my rears are squeeling at the moment. Shocked
May be worth changing the hand brake shoes whilst your there?
Good luck with it. Thumbs Up
Post #18980 28th May 2010 12:39pm
dan_uk_1984
I was going to to change the H/B Shoes but have you seen how expensive they are!? Oddly enough my hb works fine if the weight of the car is rolling backwards, but next to useless if forwards. This will be the ideal time to investigate what exactly is occurring.
Dan
Post #18981 28th May 2010 12:56pm
Your hand brake will most likely need readjusting but I can't see why the shoes need to be replaced , if you think about it really is just a small drum brake inside the rear disk and never really gets any wear unless you drive with the hand brake on and that is pretty unlikely unless the warning light switch broken. Mind you if you are in there already I guess it wont hurt either . 2008 MY Supercharged
Post #18985 28th May 2010 1:17pm
Page 1 of 5 12345>
