![]() | Home > Maintenance & Mods (L322) > Brake Disc Change |
I took that pic after a 2 mile drive back from the garage, so they weren't bedded in yet. However, now the wear band is solid and uniform. Thanks tho! |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 ![]() ![]() ![]() |
Good to know you all have my safety in mind!
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3779 ![]() ![]() |
![]() a friend did that and re-used pads that were only a few hundred miles old - he unfortunately ended up with new warped discs. |
How/Why? ![]() |
a mechanics opinion was that as the pads were only making partial contact over the whole of the disc, this led to increased friction on a smaller contact area and therefore significantly more heat generation than was design intended - which resulted in his warped discs.
Thanks for that, makes sense. However I was very gentle with the breaking for the first 200+ miles so don't think I could have heated them beyond their tolerances. At the end of the day they were cheap discs so they could just be slightly warped already.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6418 ![]() ![]() |
Just got back in from spending the afternoon changing my discs (no name) and pads (Mintex). My servicing guy identified worn discs last time round. The pads that came off had plenty of wear left, but it seemed a shame to put old pads onto new discs. Discs didn't look too bad - I would have run them on for another 30K but MOT looms.
Great Pics Joe90, they were the pics I should have taken!
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
Best 2p's worth I've seen for a while! |
Bigbangman Member Since: 10 Jun 2010 Location: Worcestershire Posts: 53 ![]() ![]() ![]() |
It's a good point Bigbangman. The Rave instructions tell you to undo the bleed nipple and push out some fluid (using tubes and bottle with fluid in it), but I have not experienced any problems with any car, with ABS, including P38A, doing it my way, and not had any warnings form the car re ABS. . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
dantheman Member Since: 02 Feb 2009 Location: North: Lancs Posts: 477 ![]() ![]() |
No problem pushing the pots back in the calipers - a wind back tool worked effortlessly for me. Probably one of the best tools I have ever bought to be honest:
Looks like I'll have to sort out a "blow mould storage carrying case with display sleeve" for my Acme ![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
