Home > Wheels & Tyres > what to do with airsuspension when changing wheels |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 809 |
sorry to ask a dumb question then.....
20th May 2013 7:52am |
Posted earlier.... |
20th May 2013 7:55am |
this is the bit i dont understand.....
20th May 2013 7:57am |
The standard Jack is not big enough to fit into locators if in off-road height therefore in most cases physically impossible to attempt. Therefore when using Standard or access and supplied jack the Wheels will droop and you need to keep jacking until wheels clear the ground.
20th May 2013 8:00am |
still dont understand - sorry.
20th May 2013 8:03am |
and this is what kwik fit were doing.....
20th May 2013 8:05am |
The supplied jack has enough winding to get the car off the ground even with the droop (just). Locating it in offroad is the issue. |
QUICK FIT are Numpties.... |
20th May 2013 8:06am |
which is how i started the thread.....how come when in kwik fit, it was not possible, even when using a trolley jack, to get the wheel off the ground when the suspension was in access mode.
it's not difficult.....
20th May 2013 8:10am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16300 |
I'll leave you 2 to it |
20th May 2013 8:11am |
Access height will have the maximum droop as explained.
and why should locating the standard jack in off road height be more of an issue than locating it in normal height?
20th May 2013 8:14am |
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 |
My manual says car must be in Off road height before jacking up 2011 car Far to many gone... |
20th May 2013 8:15am |
