![]() | Home > Wheels & Tyres > what to do with airsuspension when changing wheels |
Just follow the manual. The suspension can't "pull" the wheels up, it is just an air spring and lowering it to access mode is done by letting air out until it reaches the correct height. Then the connection is closed and the air in the spring is of the same pressure as it would be in normal or off-road height as it still needs to support the car weight in exactly the same way.
Correct procedure is to put the RR into offroad height and then open door to lock in place. At this setting the wheels will not droop when jacked up. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16312 ![]() ![]() ![]() |
Me thinks your talking about a P38 Gaz... Boot won't stop air suspension on the 322... |
OK Craig I thought it did. Still best to be in offroad to avoid droop. Thanks |
jonlewis Member Since: 06 Nov 2012 Location: UK Posts: 308 ![]() ![]() |
So.... Obvious question, what is the access mode lock actually for ? 2011 Stornaway Grey 5.0SC Autobiography |
Car parks & height restricted areas I think. |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 814 ![]() ![]() |
manual says to leave setting in "normal". doesn't say anything about opening the tailgate...... |
Manual assumes your using supplied jack (not recmmended) so normal height as it wont reach in offroad but the wheel will droop. If at a tyre shop or personally using a trolley jack under the chassis/suspension then offroad works as there is little further room to droop. |
For arguments sake, when you jack the car up, don't latch one of the doors fully and this will stop the car trying to adjust the EAS when jacking it up... Which could be dangerous...
^ I thought boot & doors did this so thanks again Craig |
No worries Gary |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
i've jacked up when its been in all three modes and it didnt make any difference....a couple a times its gone down to the bump stops when let off the jack but a start of the engine brought it back up to whatever mode i was in... ... - .- -.
so to be clear.....
A) With suspension fully extended in off-road height you only need to jack the car a few inches to be able to remove the wheel as when the body/chassis lifts the wheel will lift at the same time/rate.
