Home > Maintenance & Mods (L322) > Won't start after a run
Page 1 of 3 123>
reynolds
England 2004 Range Rover Autobiography Td6 Buckingham Blue
Has anybody had a similar problem or can any one give me any suggestions my 3 litre td6 range rover won't restart after a run just keeps turning over plenty of fuel please any help Big Cry Big Cry Big Cry [/b]
Post #185331 28th Apr 2013 6:52pm
spanner
Fuel pump under car on nearside behind rear door there is a panel remove and hit pump with hammer you will find car starts
Post #185333 28th Apr 2013 7:05pm
mjdronfield
as above - happened to me last Wednesday.
Pump is 147 plus vat retail............
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #185367 28th Apr 2013 10:27pm
reynolds
Is it a easy job to do
Post #185371 29th Apr 2013 6:21am
Or you can pay your Dealer £400 to do it. Big Cry Discovery 4 HSE
Post #185392 29th Apr 2013 7:48am
What sort of mileage do these pumps fail at generally?
Post #185425 29th Apr 2013 9:46am
reynolds
If it is the problem I have not looked at it yet mines done 80000
Post #185441 29th Apr 2013 10:28am
I think its age more than anything but they seem to last about 6-8yrs on average on here.
Replacement is dead simple, Release the cover on the passenger side, crimp the fuel line in and out and undo the plug, undo the pipe clamps, undo the clamp on the unit itself and then slide it out and slide the new one in Smile
Refit as above.
When you turn the engine on turn to the RUN position and let it fully prime until the motor shuts off and then do it one more time to purge air bubbles and then go to start it Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #185464 29th Apr 2013 11:24am
mjdronfield
If its the original, 121722 miles !!
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #185528 29th Apr 2013 3:53pm
reynolds
Fitted new pump today took it for run stiil same problem
Starts lovely when cold refuses to start when left for short while any ideas greatly appreciated
Post #185811 30th Apr 2013 4:52pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I had a similar problem on my X5, same engine.
It was the cam shaft sensor.
Post #185814 30th Apr 2013 4:58pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
+1 for CPS
Classic symptom is starts fine when cold, sensor breaks down when warm and engine wont start.
Post #185890 30th Apr 2013 10:17pm
reynolds
Excuse my ignorance but what is +1 for cps
Post #185904 1st May 2013 6:32am
Katash
+1 in a post means that person agrees with the previous post.
CPS Is cam/crank position sensor
+1 for CPS means I agree that the cam/crank position sensor.
Post #185907 1st May 2013 6:48am
reynolds
Thank you Do you know where the said item is located
Post #185909 1st May 2013 6:55am
Page 1 of 3 123>
