Home > Maintenance & Mods (L322) > Won't start after a run
Page 2 of 3 <123>
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Not sure sorry .... Someone here will be able to guide you otherwise RAVE will help.
Post #185925 1st May 2013 9:15am
ebajema
There is a PDF of the workshop manual online, you should be able to find it with that. MY 2010 5.0 SC Galway green and sand interior!!
Post #185926 1st May 2013 9:17am
Item 6
Post #185928 1st May 2013 9:25am
reynolds
England 2004 Range Rover Autobiography Td6 Buckingham Blue
Hi is that the crankshaft or camshaft sensor
Post #185956 1st May 2013 12:01pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Would it be an idea to get the codes read to try and establish the fault before you carry on changing parts?
Post #185958 1st May 2013 12:06pm
@reynolds
Crankshaft sensor Thumbs Up
Post #185962 1st May 2013 12:26pm
reynolds
I need CAMSHAFT sensor
Post #185983 1st May 2013 1:56pm
ebajema
I looked that the manual and it seems to sit underneath the inlet pipe from filter to engine on the UK driver side of the car.
Just go online and search for the manual, you can download it and you have all the info. I vaguely remember that you can find a link through the Wiki as well.
Found it http://landrover.workshop-manuals.com/l322-b/index.php?id=336 MY 2010 5.0 SC Galway green and sand interior!!
Post #185985 1st May 2013 2:00pm
Embarassed
Camshaft sensor, number 11
Post #185992 1st May 2013 2:16pm
reynolds
Thank you
Post #186005 1st May 2013 3:12pm
Katash
Personally I'd say you need to look at the crank sensor not the cam sensor
Confused myself with my original reply post so googled 'What is the difference between camshaft and crankshaft sensor?'
Got the following answer:-
Quote:
Answer
Cam sensor usually senses the position of the timing belt or timing chain gear and tells the computer when #1 cylinder is at top dead center. In other words, when #1 cylinder comes up. Crank sensor tells the computer when to fire the spark plugs in the rest of the cylinders. In other words, as ther crank shaft goes around it tells the computer when each piston comes up so it can fire it's spark plug.
In my experience (not personal but know a few people who have had this issue) its usually the crank sensor that plays up, possibly due to its position it picks up moisture and fails - a simple google search for
'car wont start when warm cam position sensor' returns alot of hits.
I'm quite possibly wrong tho so as PaulB said its probably best to get the codes read first, although the crank sensor should be quite easy to get to and change/test.
Post #186064 1st May 2013 7:19pm
wslr
United Kingdom 2010 Range Rover Vogue SE TDV8 Atacama Sand
Most engines will run with a poor cam sensor reading but as mentioned all along, the crank sensor is a critical sensor without which an engine will not run at all.
Given that it starts ok from cold, perhaps you have a faulty temperature sensor (fuel or ambient air temp) which is confusing the fueling for the hot starting? Air flow meter is another sensor which could affect it.
Post #186077 1st May 2013 9:02pm
reynolds
Took it in today to range rover dealer today problem is it needs 3 injectors to rectify starting problem
Post #187402 9th May 2013 12:52pm
ebajema
Sorry to hear. It seems to be the month for the TD6 injectors going Sad MY 2010 5.0 SC Galway green and sand interior!!
Post #187415 9th May 2013 1:22pm
Cmgrob
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
Just to throw in my 2p's worth, the cam sensor on the td6 is located under the plastic trim on top of the engine, the diagrams above are from the v8 and located in a completely different place 👍
Post #322156 11th Apr 2015 9:16am
Page 2 of 3 <123>
