Home > General > Well I've lost my breakdown virginity. |
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 |
Just driving back home tonight and got 5 miles away from home when fuel inject system flashes up and I lose all power, power steering, power assisted braking the works.
23rd Apr 2013 10:09pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2618 |
After the 3rd time , I bit the bullet & joined the AA |
23rd Apr 2013 10:14pm |
Already taken the bite, otherwise I'm not getting home tonight, lol Bushy
23rd Apr 2013 10:16pm |
I've got 4 months used warranty left so hopefully will be covered with that. Bushy
23rd Apr 2013 11:14pm |
Any update at all?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
24th Apr 2013 5:06pm |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
Hopefully he is not still out waiting for the recovery van. Tom
24th Apr 2013 5:38pm |
barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213 |
If he is with the AA that is very possible! |
24th Apr 2013 7:25pm |
AA man couldn't sort it out either, I'm trained as a mechanic and pretty much told him, he wouldn't be able to fix it lol.
24th Apr 2013 9:33pm |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 |
I had almost exactly the same symptoms as you describe on my TD6, only difference was if I left the ignition on for 2 mins with the fuel pump priming and did this a couple of times it would eventually start. Anyhow to cut a long story short it only occurred when the fuel was down to about a quarter of a tank. Happened a couple of times while I was diagnosing the issue. Turned out to be a faulty in tank fuel pump which was not siphoning fuel from the left saddle side of the fuel tank. Replaced pump and now its been fine. Obviously yours could be some other failure but thought I would let you know just in case it helps. |
27th Apr 2013 6:12pm |
It's still at the stealers atm but they are changing the filter first, before going back to the in tank pump. Personally I hope it is the pump otherwise the warranty won't cover the filter, and I'll end up paying over £100 just to have them replace a 5 minute filter. Bushy
27th Apr 2013 6:20pm |
If its the intank pump could you ask to keep the old one as i may have a use for it if thats ok??
27th Apr 2013 9:23pm |
Sure no problem mate. Bushy
28th Apr 2013 9:25am |
Cheers fella FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
28th Apr 2013 11:01am |
It's the external pump Kingpleb, I don't know if thats any good to you? Bushy
29th Apr 2013 1:06pm |
