![]() | Home > General > Well I've lost my breakdown virginity. |
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 ![]() ![]() ![]() |
Just driving back home tonight and got 5 miles away from home when fuel inject system flashes up and I lose all power, power steering, power assisted braking the works.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2672 ![]() ![]() ![]() |
After the 3rd time , I bit the bullet & joined the AA |
Already taken the bite, otherwise I'm not getting home tonight, lol Bushy
I've got 4 months used warranty left so hopefully will be covered with that. Bushy
Any update at all?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
Hopefully he is not still out waiting for the recovery van. Tom
barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213 ![]() ![]() ![]() |
If he is with the AA that is very possible! |
AA man couldn't sort it out either, I'm trained as a mechanic and pretty much told him, he wouldn't be able to fix it lol.
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
I had almost exactly the same symptoms as you describe on my TD6, only difference was if I left the ignition on for 2 mins with the fuel pump priming and did this a couple of times it would eventually start. Anyhow to cut a long story short it only occurred when the fuel was down to about a quarter of a tank. Happened a couple of times while I was diagnosing the issue. Turned out to be a faulty in tank fuel pump which was not siphoning fuel from the left saddle side of the fuel tank. Replaced pump and now its been fine. Obviously yours could be some other failure but thought I would let you know just in case it helps. |
It's still at the stealers atm but they are changing the filter first, before going back to the in tank pump. Personally I hope it is the pump otherwise the warranty won't cover the filter, and I'll end up paying over £100 just to have them replace a 5 minute filter. |
If its the intank pump could you ask to keep the old one as i may have a use for it if thats ok??
Sure no problem mate. Bushy
Cheers fella |
It's the external pump Kingpleb, I don't know if thats any good to you? Bushy
