![]() | Home > Technical (L322) > FBH Heater - Webasto Remote |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
Thanks Martin, I love the level of knowledge on this and the other forums |
prohunter Member Since: 26 Mar 2013 Location: Scotland Posts: 4 ![]() ![]() |
http://www.flickr.com/photos/94640770@N07/...hotostream
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
uploaded the pics for you,
Thank you!.... |
er, nothing...but if you mean getting the pics to show then this is what you need to do,
Thanks! |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 ![]() ![]() |
Yes, just join it to the WBUS output from the T90. In your photo this is the yellow wire (colours are different to the diagram I have but pinout the same). FYI Brown is ground and Red is 12V. Yep the 1533 oval timer and the T90 use same comms bus (WBUS). Just splice the WBUS output wire from the 1533 into the yellow wire from the T90. Anything else you need to know just shout ![]() |
razvanm3 Member Since: 26 Sep 2013 Location: Timisoara Posts: 2 ![]() ![]() |
Hello!
If I were you I'd just buy another remote, surely a t91 will do the job and they are only £15 |
uzp315 Member Since: 19 Nov 2017 Posts: 428 ![]() |
Thanks Prohunter/Andy, I have a 2007 TDV8 3,6 Vogue SE with a T90 receiver. I bought a T91 remote and pulling the front fuse No. 59 had no effect, but pulling the rear fuse No. 16 for 15 seconds and then pressing the "OFF" on the remote did the trick immediately - I might have been stuck without this advice. The manual gave no real clue that this No.16 rear fuse was related to the FBH ![]() Best regards Mark |
