Home > Technical (L322) > Swapping Xenon to non-xenon headlights
jerrytlr
France 2003 Range Rover Vogue 4.4 V8 Oslo Blue
Hi all
I need to swap the headlights from a UK spec 2003 vogue (xenons) to LHD-spec lights for registering the vehicle in France.
It seems much cheaper and easier to find non-Xenon (halogen) units second hand. Does anybody know if I can replace the Xenon units with halogen units without overly complex wiring and/or lots of bulb failure type error messages appearing?? I'm not too fussed about whether I have xenon or halogen.
TIA
Best regards
Jerry
Post #181004 3rd Apr 2013 8:07am
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
Why? ...just switch them to lhd. It only takes 5 minutes
That's all I had to do to get it through the CT
Post #181005 3rd Apr 2013 8:17am
fullfats have a little lever in the headlight enclosure that when switched allows us to drive in france etc.....as said switch this over for the test.. ... - .- -.
Post #181009 3rd Apr 2013 8:28am
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
From memory you have to have a LHD beam pattern to register a car in France - the headlamp shutter lever masks off the RHD nearside high lights (which normally light up the kerb/ pavement) - but it doesn't give you a proper LHD beam (just a flattened RHD beam).
Post #181016 3rd Apr 2013 9:01am
Exactly right VagelyVogue the light go from RHD to flat beams so as not to dazzle... To pass a french test they must be LHD lights...
You can plug halogen or xenons in on an 05> facelift without issue but only if you dont have cornering lights...
Craig Thumbs Up
Post #181022 3rd Apr 2013 9:25am
SFM
Well both my BMW and TDV8 passed by just doing this.
If you really want to spend €1000 + changing the head lights + €800+ CO2 import tax + £100 certificate of conformity etc it's up you.
It's not cheap to import a luxury car into France, but still a lot cheaper than buying the same over here.
Where abouts are you based?
Post #181027 3rd Apr 2013 9:58am
jerrytlr
Thanks for the input - seems like we have two different opinions re what is required to get through the French CT! Will probably ask my friendly CT man to take a look before I spend €€€ on new lights.
Craig - do you know if the same is true for pre facelift cars, i.e. the headlight units can be swapped for halogen ones? The car I am hoping to buy is 2003.
Thanks again for all the help, I'm very pleased to have joined this forum!
Cheers
Jerry
Post #181028 3rd Apr 2013 10:04am
SFM
Sorry guys
Didn't mean to come across as a know all!
Yes you are probably right that by switching, they are never going to be "true" lhd lights, but myself and 3 other of my friends have done this on their disco`s and Rangies, and all have passed the CT, when I brought our old P38 over, it cost me €600 to change the lights.
Post #181029 3rd Apr 2013 10:20am
verydisco
Hi
sligth, off topic, but I have 2 French LHD adaptive xenon headlights for sale if that may help you getting it all straight.
Where are you lads about in Cheese country? l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #181031 3rd Apr 2013 10:48am
SFM
In between Bergerac and Perigeaux....and you?
Post #181032 3rd Apr 2013 10:59am
jerrytlr
I'm in the Perigord, so more apples and Fois Gras than cheese.... right up in the north east corner of the Dordogne.
Verydisco - would certainly be interested in your lights but if they are adaptive I am guessing they are post-facelift so won't fit my (intended) 2003...?
Cheers
Jerry
Post #181047 3rd Apr 2013 12:45pm
verydisco
Non, they will not fit unless you get the whole kit kit if you want to get a 2006/2009 facelift (got it all)
I am around your neck of the woods lads. PM for precise location.
Cheers l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #181051 3rd Apr 2013 12:55pm
Googsy
I sense a wine session Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #181307 4th Apr 2013 6:00pm
