Home > In Car Electronics (L322) > Digital TV Upgrade |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
Hi Steve, Thanks for the pdf, does make it look quite straightforward. Called dealer today and the unit has arrived, but there's a bit of extra info now. The price is actually @£424 for the digital unit, but if you give LR the old analogue one back, you get £100 off the bill , hence costs £324. (Dealer does not have to remove it, you just have to return the old unit after fitting the new and claim the £100 surchagre back). Seems OK as the analogue is of no use in this country and I don't think I could recover the £100 and shipping costs by trying to sell it online to someone abroad whose analogue unit has failed). Dealer thinks they do need to synchronise the new box so I've told them it should take 30mins to fit and then the time to start the software update and then to check it's updated Ok, not paying for the upload time though.So, it's going in on Friday morning and I'm waiting for the car. I'll get the part #s for you all then and let you know how I got on. Cheers Steve
8th May 2010 11:54am |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
hi, what are they charging you to fit the unit... V8 facelift Range Rover Autobiography 22" wheels.
8th May 2010 1:14pm |
I think their hourly rate is @£75 (they have already stated a max of 2hrs but I'm aiming for the 1hr fee).
8th May 2010 4:28pm |
hi, i did post..you don't need it to be coded to the car, it should have the latest software version on it as its new, you will need to set it up and search for new channels but you would do that any way and that's done from the head unit...
8th May 2010 5:03pm |
Thanks Dave, so have you actually fitted the LR digital upgrade yourself already? Its just that any 'freeview' system I've used has totally different menus to the UHF analogue ones and I couldn't see how the touch screen would handle the digital frequency listings (do you end up with 50-60 icons scrolling off the screen display with the channel names on?) unless the software was changed. If you're saing the inforamtion and menu format is generated by the new digital box only, then I'll quite happliy fit it myself. Steve
8th May 2010 5:17pm |
hi, yes i changed my one my self, my one is a 2005 unit and is slighty different unit but is the digital version of the one that was there but when my mate bought his 2006 the tv did not work correctly, the dealer supplied a second handone and he fitted it, no coding was needed. now we dont know if the one that came out was digital but the one that went in was.
8th May 2010 6:11pm |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 |
£75 an hour!!!!!
8th May 2010 6:28pm |
Hi Dave, Thanks for that, was your mates a touch screen system in his 2006 RR or the older BMW 'X5' one? Steve
8th May 2010 10:54pm |
Hi Steve, I had the same charging issue with my Lotus Carlton, the Vauxhall dealer charged £70 per hour (this is in 1996!) for the Lotus, but £34 for other Vauxhalls. I challenged it and asked if they worked harder than the other 'fitters' , they told me it was to cover the cost of their specialist Lotus training 4yrs prior. I said as no one was now being trained, I would not cover the garages past costs (their choice to become a Lotus C. dealership) and from then on paid £34/hr like any other Vauxhall. Mind you, they easily made their money on the parts which even with the 20% discount I managed to get out of them, ran into £100s & even £1000s per part!!! Steve
8th May 2010 11:00pm |
hi steve, my one was the older bmw system but my mate was the touch screen, when he changed it he didnt even know that they came with free view, his one never had it...it was luck,the dealer must of removed it from one that did..
9th May 2010 9:16am |
I've just had another look through the installation instructions I posted earlier. It looks like I included the incorrect pdf document. It was the same procedure but finished with removing the audio amp. The updated file continues with the tv tuner removal and states at the bottom of the page that the vehicle should be connected to diagnostics to configure the module...
9th May 2010 9:43am |
land rover would say you need to have your car coded after replacing the indicator bulb,if they could get away with it...i have changed several modules and never needed them coded despite what they said..
9th May 2010 12:11pm |
I'm with you on this one, I'd much rather give it a go myself on the off chance that it would work. I think my money is better off with me instead of lining the dealer pocket! And like you say, you won't lose anything trying. |
9th May 2010 3:29pm |
I have to admit, one of my original thoughts for having the dealer do it was because for months LR and the dealers said there was no upgrade available, then I find out by chance there now is. I then thought that maybe the parts lad had got mixed up and ordered me the digi unit for a Mdl yr 2007 and so if I fit it myself and it was the wrong part, they might not take it back or charge me the 20% returns fee . Hence, if the garage did it and it was not compatible, then I would pay nothing as they had supplied & fitted the wrong part. However, everything I'm now hearing on the forum backs up the idea that they have decided to do a retro fit unit and so should work. I'm now sorely tempted to just fit it myself and as you say, if it works, great, if not, take it to the dealers to finish the job off with coding etc. Thanks for your help with this Dave/Steve Steve
9th May 2010 10:40pm |
