![]() | Home > In Car Electronics (L322) > ecu problem. |
Did you try the fuses? Present :2008 TDV8 HSE
henry nelson Member Since: 09 Oct 2011 Location: carlisle Posts: 43 ![]() ![]() ![]() |
yes i have tried every thing, looks like a ecu fault. At the moment i can live without memory and elec steering adjust. I will get it fixed at some point. |
Where is the ecu? and can i check the wireing with out |
Try finding the workshop manual online, it is in PDF (too big to email) and has a lot of info for the 2002-2005 models like yours. It shows you where the ECU is amongst others.
Had the battery disconected today by inde, plus he joined batt leads together and still no faults showing on his laptop( it is a blue one if that means anything) everything just said inactive. That is when he said maybe is bad conection. |
I had a look at the workshop manual and the BCU is controlling the seats. It controls a lot of things by the way, not sure if it does the steering as well, but try to get it and have a good read, it is 28+MB and some 800 pages. MY 2010 5.0 SC Galway green and sand interior!!
Had a look at the file you said but it did not tell me if i can disconect bcu without |
I have not worked on a BCU but what I remember reading here and/or on www.blackbox-solutions.com is that you need to remove the seat (believe it is only for bolts on the rails). Then you have the BCU in full view. In my experience, most plugs are seated really well with locking tabs and the likes but maybe one was not put back properly after someone worked on it, so first I'd push them in to see if they are seated properly. If all of them are (the BCU seems to have 3) then it is time to remove them, clean them as far as possible and spray with contact cleaner. Hope that does the trick |
Cheers thank you, i will have a look on my next days off. |
When you say remove the plugs do i have to disconect the battery first and does it throw any faults up when conected up again, ie will i need to have it put on the pc to get everything working again. I don`t want to take it off if it will cause even more problems. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
I can read your codes if you wish... |
I don't think a new BCU is that expensive. Ask Dan @ Duckworths.... |
New they are under �200 including VAT. |
Hi cam tech craig, that would be fine but there are no codes there to read, the screen is blank where they should be. |
