Home > In Car Electronics (L322) > ecu problem.
henry nelson
England 2003 Range Rover HSE Td6 Adriatic Blue
ecu problem.
Hi everyone, just had my rr checked because the electric steering in out up down not working, also seat memory, independant says there is no signal from ecu- ie any fault issues. Ecu says seat memory-steering inactive. Won`t reset, also tick over won`t reset, He says either water ingress or bad conection on ecu. Anyone any ideas. Cheers Henry.
Post #176777 9th Mar 2013 4:57pm
Googsy
Did you try the fuses? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #176785 9th Mar 2013 6:56pm
henry nelson
yes i have tried every thing, looks like a ecu fault. At the moment i can live without memory and elec steering adjust. I will get it fixed at some point.
Post #176787 9th Mar 2013 7:09pm
henry nelson
Where is the ecu? and can i check the wireing with out Censored it up all together.
Post #176789 9th Mar 2013 8:06pm
ebajema
Try finding the workshop manual online, it is in PDF (too big to email) and has a lot of info for the 2002-2005 models like yours. It shows you where the ECU is amongst others.
Also try to disconnect both clamps from the battery poles (after following the Wiki battery disconnection procedure) and hold the clamps together for 10 secs. This drains the ECUs power reserve and clears faults from the fault memory.
Then try again and if it still won't work, try to find someone with a diagnostic tool IID, Faultmate or the likes to see if there is any faultcode that will help you. MY 2010 5.0 SC Galway green and sand interior!!
Post #176791 9th Mar 2013 8:38pm
henry nelson
Had the battery disconected today by inde, plus he joined batt leads together and still no faults showing on his laptop( it is a blue one if that means anything) everything just said inactive. That is when he said maybe is bad conection.
Post #176792 9th Mar 2013 8:46pm
ebajema
I had a look at the workshop manual and the BCU is controlling the seats. It controls a lot of things by the way, not sure if it does the steering as well, but try to get it and have a good read, it is 28+MB and some 800 pages. MY 2010 5.0 SC Galway green and sand interior!!
Post #176794 9th Mar 2013 8:55pm
henry nelson
Had a look at the file you said but it did not tell me if i can disconect bcu without Censored it up compleatly-is it posslble to wiggle the conections about to make sure they have a good contact.
Post #176796 9th Mar 2013 9:25pm
ebajema
I have not worked on a BCU but what I remember reading here and/or on www.blackbox-solutions.com is that you need to remove the seat (believe it is only for bolts on the rails). Then you have the BCU in full view. In my experience, most plugs are seated really well with locking tabs and the likes but maybe one was not put back properly after someone worked on it, so first I'd push them in to see if they are seated properly. If all of them are (the BCU seems to have 3) then it is time to remove them, clean them as far as possible and spray with contact cleaner. Hope that does the trick Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #176801 9th Mar 2013 10:08pm
henry nelson
Cheers thank you, i will have a look on my next days off.
Post #176802 9th Mar 2013 10:12pm
henry nelson
When you say remove the plugs do i have to disconect the battery first and does it throw any faults up when conected up again, ie will i need to have it put on the pc to get everything working again. I don`t want to take it off if it will cause even more problems.
Post #176919 10th Mar 2013 8:38pm
I can read your codes if you wish... Whistle
Post #176951 11th Mar 2013 10:13am
I don't think a new BCU is that expensive. Ask Dan @ Duckworths....
Post #176953 11th Mar 2013 10:33am
New they are under �200 including VAT.
Post #176955 11th Mar 2013 10:38am
henry nelson
Hi cam tech craig, that would be fine but there are no codes there to read, the screen is blank where they should be.
Post #177048 11th Mar 2013 8:21pm
