Home > In Car Electronics (L322) > Amp socket burnt out, easy to replace? |
I'd say some water has caused that so best to identify the route cause if you haven't already done so.
10th Jan 2013 3:01pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
If you were to carefully take the plug to pieces and note the position and colour of each wire connected to it shouldn't be too dificult to fit a new plug to the harness, assuming the harness is long enough to reach to the amp socket with a new plug fitted.
10th Jan 2013 3:06pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Try VWP - vehicle wiring products for a new connector.
10th Jan 2013 3:27pm |
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 |
Does anybody know what the part number is?
11th Jan 2013 12:40am |
Yes, the loom is ridiculously expensive and covers half of the back of the car meaning installation is also ridiculously expensive. And finding OEM connectors such as this new is extraordinarily difficult. That is why headlight plugs for facelift conversions were selling for GBP 65 or even more on ebay...
11th Jan 2013 7:30am |
It was water ingress, 5 days of continuous rain over Christmas
11th Jan 2013 4:37pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3143 |
MRD, I have a non-working one of these which you can have - the only damage is one of the spikes in the socket snapped under corrosion, meaning I couldn't get sound on one side of the car; otherwise it works. You may be able to swap them over. PM me if you like. |
11th Jan 2013 5:43pm |
Thanks for the offer, not sure I'd be able to fix the broken pins which is a worry. I'll have to source a working one somewhere, maybe the breakers will have that too ( should have asked them, d'oh ) |
11th Jan 2013 7:17pm |
You could bye-pass the broken pin by going into the unit, soldering a thin wire onto the relevant socket connection, bringing the cable out of the unit casing and connecting directly onto the relevant plug cable.
11th Jan 2013 8:21pm |
Job done!
14th Feb 2013 4:44pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
blimey looks like one of those BT sub station boxes...good job ... - .- -.
14th Feb 2013 4:46pm |
klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 210 |
did you solder the wires together ? 1990 3.5 v8 defender
14th Feb 2013 7:45pm |
I used connection blocks for the thick wires and for the small speaker wires I used my old tried and tested method of stripping back 5 cm of skin, then twisting the wires until they stuck together solidly, electrical insulation tape to seal and protect each connection. The entire cable will be put in plastic piping so it's future proof.
14th Feb 2013 7:55pm |
ccfj1 Member Since: 14 Feb 2013 Location: UK Posts: 32 |
^^ No offence mate, twist and tape is in no way good enough for the power that will be going through them wires.
15th Feb 2013 9:55am |
