![]() | Home > Technical (L322) > HDC Inactive, Air Suspension Locked... |
I removed the plugs for the rear sensors and stuck an ohmmeter on the pins, the N/S gave a reading of around 1365 and the O/S gave a reading of 1 so I now need to double check with the garage what the Autologic 'left side' means as it's my O/S that looks to be at fault.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Left is from the back of the car with All Comms (USA) and IIDTool (Canada/Europe) if that helps? Maybe both sides are |
Thanks Joe, will contact the garage in the morning |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2685 ![]() ![]() ![]() |
Fook, that's mine on the blink now, locked in normal height, no lights on controller, bong + warining of max 30mph in offroad height! Too good to be true, not had any issues for 6 months, bastid car! |
The joys of owning a Range Rover |
Aye, lulled into a false sense of security then bang, more cash to thrown about! Sadly don't have a code reader so another trip to the garage!Thinking about what i've spent on the car in the last 3 years, i could easily afford a cayenne turbo..... |
Found this on Landyzone, anyone know if it works??
ksmith100 Member Since: 20 Apr 2012 Location: Stirling(ish) Posts: 77 ![]() ![]() ![]() |
Never got it to work on mine even though it goes through the motions. Mine has the touch screen nav which may be the reason. I cant select the number with the left button as per the instructions |
Will try the battery disconnect 1st then take it from there, sadly no-one local has autologic, unless anyone knows somwhere in tayside?? |
Have you tried steering turned lock to lock yet? |
Just removed the other sensor, again it came out in bits then I gave the bore holes a clean up with the Dremel. When I fit the new sensors I'll put some grease around then to prevent them seizing in again
Fitted the 2 new sensors this morning and took the FFRR out for a run, so far no problems but I won't rule out more problems just yet |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
You da man... |
Cheers CB, I was going to run over to the garage and have it plugged into Autologic again, but it's a 30 mile round trip so I'll wait and see how it goes first |
