Home > In Car Electronics (L322) > Aftermarket? |
djharm Member Since: 28 Dec 2012 Location: breda Posts: 78 |
What are the problems? |
6th Feb 2013 10:21pm |
SATVC Member Since: 25 Nov 2012 Location: Surrey Posts: 172 |
Only issues with fitting after market units I can see are adjusting the clock and resetting mpg etc??
6th Feb 2013 10:25pm |
What are your problems with the OEM system I meant.... |
6th Feb 2013 10:37pm |
Sorry
6th Feb 2013 10:42pm |
I have had similar problems, I took all units out to find out what the problem was. Obviously water damage, pins of the TV-unit where rusty, so I cleaned them out and had to solder the positive + straight from the print to the cable cause the pin broke while cleaning, and wanted to try to get it to work before spending money. After that everything worked well except for my NAV witch I had to replace for the 2nd time . Since then I kept my AC on all the time and haven't seen any water since. But I did cover everything with some plastic's.... just in case.. |
6th Feb 2013 10:56pm |
I've had a look at most of the plugs and all seams ok? When I get some time I'll go through everything with a fine tooth comb!
6th Feb 2013 10:59pm |
Do you have a blue screen? or nothing at all? |
6th Feb 2013 11:08pm |
Nothing, just a back light! |
7th Feb 2013 8:25am |
And if you take out the MK4 unit? |
7th Feb 2013 11:28am |
Nothing, just the back light? I plugged it into the tuner plug aswell with no joy,
7th Feb 2013 6:38pm |
Take out the MK4 anyway, and try to find a TV tuner, the are not so expensive. I've seen them go for 60 to 100 pounds. try to go from there, you might end up cheaper than replacing for aftermarket. |
7th Feb 2013 7:39pm |
I've finally decided a new double din aftermarket system is the way forward.
13th Feb 2013 4:55pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35293 |
the new head unit will probably have all the connections you need if its for the fullfat , mine did for my smax.. ... - .- -.
13th Feb 2013 4:58pm |
It's not the range rover screen going in it'll be a pioneer double din, I'll be losing all the standard screen,amp, dsp, tuner, sat etc |
13th Feb 2013 5:25pm |
